Hi
should we now feel that the fuse is not blowing after second time soldering?
coming to smps tranformers, the parameter to be checked is inuctance of the primary and secondary coils, turns ratio (Np and Ns, and cross insulation of secondary wrt primary.
as you switch the rectified DC using a high frequency of the order of Few KHz, DC coil resistance has no relevance. some times when operating frequency goes to few hundreds of KHZ, turns come down to 20etc, and windings will be paralleled in order to increase cureent carrying capacity.
i was asking you to test smps exclusively with an artificial load, say two 12Volt bulbs, in series to make 24 volts .or a resistor as i suggested,
mean time you can check for vertical section driver IC or final stage transistors, anf the final transistorof line output for short.
