Soft Power Up?
dpresley58
Aug 10, 2009
9
I've built a small transistor-based preamp and powered it with a standard 9v battery. Its using a SPST switch to which the ground is hooked to turn it on. The problem is that there is a substantial thump when the switch is thrown, and I'm looking for a solution with a small component count that would slowly ramp the power to the circuit in hopes that approach would eliminate the pop.
Is there a simple approach to this?
audioguru2
Apr 6, 2004
12,022
Post its schematic for us to see if its biasing can have a slow ramp-up.
dpresley58
Aug 10, 2009
9
Thanks. The schematic is under Topic 9 of this link.
http://runoffgroove.com/fetzervalve.html
Although the author used pots for dialing in the source and drain resistors, I've calc'd resistors for the individual transistors. He shows a small breadboard jig for measuring these values. Since my application is stereo, I had to find 2 trannies that were more or less matched. I'm using the J201, by the way.
audioguru2
Apr 6, 2004
12,022
The Jfet is self-biased so its output suddenly jumps up when its power supply voltage is applied.
If you slowly ramp up its power supply voltage then it should not make a POP sound.
dpresley58
Aug 10, 2009
9
What would be a good method of doing this while keeping component count down? A decent-sized cap (100uf) with a pull-down resistor to ground on the way from the switch to the board?
audioguru2
Apr 6, 2004
12,022
Since you are switching its ground instead of switching its positive supply to turn it on and off then ramping the power supply voltage must also be done backwards. A PNP emitter-follower transistor can provide the Jfet preamp with a ramping 0V.
dpresley58
Aug 10, 2009
9
I see what you're saying... Not particularly married to the switching situation - the positive could be used just as easily, since it only really amounts to breaking the battery leads with a switch. I'll look into the emitter-follower.
And thanks...
audioguru2
Apr 6, 2004
12,022
If you switch its positive supply then an NPN emitter-follower can provide a slowly ramping positive supply to the Jfets.
