O
Oppie
- Jan 1, 1970
- 0
I have a milling machine that's starting to show its age. It has a 5 Hp,
208V, 3 Ph spindle motor that's currently on a full voltage Fwd/Rev starter.
Motor really slams when turned on and has damaged the variable speed sheaves
and keyways.
Was thinking of adding a soft start system in series with the original
starter. Considered a VFD but have heard that using one with a motor not
designed for such makes problems. Even adding a line reactor to remove
harmonic content may be required. All told, a soft starter appears to be the
best choice.
Does anybody have a favorite unit to recommend?
Ones I've seen so far have a SCR in series with two of the three legs and
control starting voltage and ramp-up time. If you keep them powered, they
can also control ramp-down time. A contactor bypasses the reduced voltage
system after the ramp time. All fine and well but only some of the vendors
seem to rate # of starts per hour. I would assume that this is due to heat
generation when the SCRs are carrying the load and the need to dissipate it.
Thanks in advance for any answers
Oppie
and keyways.
best choice.
Oppie
