Solar to motor
lilfear1
Jul 30, 2016
21
I recently bought a 6V solar panel when it came in the mail today I soldered a wire to it and hooked it up to a small motor that came with my arduino. Nothing happened. I checked voltage coming out of the solar panel and I am getting 5V. I connect the motor to a AAA battery and motor runs fine AAA batteries as you know are only 1.6 ish volts...What is the problem?
14,470
The solar panel may not have the current capability required by the motor
The 5V you measured, is that with or without the motor connected ?
you have told us the voltage of the panel, what is it's current capability ?
lilfear1
Jul 30, 2016
21
that is without. It is a 6V, 0.6W panel...I have no information about the DC motor at all.
14,470
OK so that 6V is likely to drop to around 4V under load and lower under a heavier load
so as I suggested in my first post, the panel probably doesn't have the capability to power that particular motor
Chemelec
Jul 12, 2016
291
Based on 0.6 watts and 6 Volts, the Maximum current is 100 mA, and that will be under BRIGHT Sun Light.
Actually, most likely it will have an open circuit voltage of 6V and a short circuit current of 100mA under specified (and likely unreproducable) conditions.
You may get 90% of the peak current at 80% of the peak voltage if you can manage your load properly
100 mA might be enough the run the motor, but not to start it. You could try spinning the motor once it is connected and see if it continues to spin.
lilfear1
Jul 30, 2016
21
I could try that thank you....I have another issue with these panels (2) they are both identical in every way. I checked voltage on both panels, I got the same volts, So I wired them in series and I got 0.00V WTF? I made a drawing of my wiring and the problems I am having. I am only testing voltage right now. I will deal with the motor later.
14,470
you probably wired them incorrectly and looking at your pix, that would be a confirmation
do this
Doug3004
Sep 5, 2014
119
Most of the solar car kits use a coreless motor, not a regular brushed-DC motor.
Coreless motors spin much easier than normal motors.
Look on Google for a "K30 solar motor".
lilfear1
Jul 30, 2016
21
do this
lol omg how stupid I was...I was looking at the panels wrong...thank you for your clarification...now getting around 9V which is better than 0.00V...it helps when it is hooked up right.
14,470
hey it happens ... at least you are sorted out :)
lilfear1
Jul 30, 2016
21
10.6V / 1.7 A = 6.23 W that isnt enough to run my little motor...even when I spin the shaft...no worries another project in the works...thanks for everyones help with my stupidity :)
14,470
in series you only double ( approx.) the voltage the current stays the same the ~ 100mA
in parallel, you double the current ( approx.) and the voltage stays the same
