Solder Rash?
Gadgetastic
Nov 22, 2011
27
Over the last few days I've spent a lot of time desoldering from old boards. Yesterday I noticed that the skin on my face was red and irritated. I did some research and found some indication that solder fumes can do this. Has anyone else ever had this happen? Just looking for some independent confirmation. Thanks.
14,490
not in the 40 years i have been working with solder and solder fumes
but as with any allergic reaction they can affect different people in different ways
Most of the fumes come from the flux, not the solder.
davelectronic
Dec 13, 2010
1,087
Hi there. I dont come out in a rash, but if i am soldering for a long time the fumes make me feel a bit unwell, as stated different people affected in different ways, flux and lead fumes are both toxic, for prolong periods you might concider an extractor or build one. Many years ago casting fishing weights in lead had the same affect on me, melting lead on a stove, terrible head aches. I use lead free with a high silver content, but its expensive and still contains flux, but i find its better than lead.
jackorocko
Apr 4, 2010
1,284
You have been unsoldering old boards? Depending on how old they might be the chemicals may be far worse then they are today. You should make sure that you are in an environment that promotes good air circulation. Try to keep your head off to the side, not directly over the board when you heat the solder.
I am not sure I would consider a rash an allergic reaction, but if you start getting patchy red bumps (hives) on your skin then that is different story. Be mindful of how you feel and keep benadryl on the ready. Otherwise you might just be overly sensitive to something in the fumes. It very well could pass and completely go away if you keep doing it.
Take it from someone who has allergies and also has sensitive skin, fortunately I am allergic to the great outdoors and not anything solder related.
jackorocko
Apr 4, 2010
1,284
I should add, if you are that worried about it, go see a doctor. Your health is more important then anything. If you can't afford to see one then you have a choice to make.
But, if your throat hasn't swollen shut yet, it most certainly won't by the time you read this.
Blue_fog
Nov 30, 2011
17
Don't do soldering work for a few days. If the problem persists then it might be smething else.
