Solder smd
Robertjohn
May 11, 2023
Hi all
Trying to find the correct solder/flux that is not thick when looking at vidio of people changing smd item the solder/flux is very thin like water, I use xgz40 and it very thick so Soldering hdmi ports is a pain as tracks conection
What do other people use ??? Or do they thin down what I use ?
John
bidrohini
Feb 1, 2023
219
Thinning down flux is not recommended to do so because it can change the chemical composition of the flux and affect its effectiveness. Instead, you may want to consider trying a different brand or type of flux that is thinner and easier to work with.
Delta Prime
Jul 29, 2020
2,993
I prefer the "easily melted"
Tin 63%/Lead 37% or "eutectic"mixture of Sn63%/Pb37% rosin core flux solder wire . paste. As above try different manufacturers flux.
