Sony Beta
GregS
Working on a delux version of the VCR. There is a little white
lever in the upper right of the loading mechanism that is preventing
insertion of the tape. I just wondered if this was a common lever
in some versions ??
This thing weighs at least 35 lbs.
greg
W
William Sommerwerck
in some versions?
That's an awfully heavy lever. (ba DUM!)
GregS
erm, which model? sony did about two dozen , you know....
SL-HF900
I think there was a manual for this around, but the main person passed
and that might be a problem.
greg
W
William Sommerwerck
SL-HF900
passed and that might be a problem.
I own this unit, and have the service manual. (Certainly one of the classic
Betamaxes. Best timer-setting system ever, in any VCR.) If you could ask a
specific question, I'll try to find the answer.
GregS
There is a white lever preventing insertion of cassette. I can't
see anything to make it move. Its either out
of position or something else is broke or missing.
if I remove the lever it will otherwise work except the mechanism
may be unsable.
http://zekfrivolous.com/sony/
greg
W
William Sommerwerck
see anything to make it move. Its either out of position or
something else is broke or missing. if I remove the lever it will
otherwise work except the mechanism may be unsable.
Give me an hour or two to get back to you on this. I'm in the middle of some
things that have to be completed. Thanks for your patience.
GregS
If it just prevents tape insertion it's probably there to prevent the
tape from being inserted unless the threading carousel is in the
correct position.
Well there is nothing wrong with that. Its my Beta test cartridge thats
at fault. ??
I am now working on the real problem. Looks like sticky feed motor.
greg
GregS
at fault. ??
Fixed that, now the tape will not move much or none in rewind or FF.
It works in play mode in forward and reverse. Glad I don't see
much of these anymore. taking the motor head off gave me Deja Vu
I think I have done this before. Seems this or another Beta
recorder had some Sanyo power module problems. The modules
were replaced..
greg
W
William Sommerwerck
rewind or FF. It works in play mode in forward and reverse.
Though unlikely, don't rule out a high-friction cassette.
GregS
Don't remember enough about every Betamax unit I've worked on to
picture the tape drive. You could be right about an underpowered
motor. I own a Sony SL-HF something, it's up in the attic. it doesn't
have a jog shuttle like the SL-HF900 but was/is a damn good unit.
It employed a belt and idler to drive the reels if my memory is
correct.
I got two more SL-HF900's. Seems like all have common sticktion problems.
I had the transport motor system out 3 times on the first machine.
That a bitch to do. I also heard its hard to get new tapes.
I also looked at another model Sony lying around and a belt was
finished on that model. The first machine works fine in play and record,
and fast play in forward and reverse, but has winding problems.
I don't know, the motor has a lot of torque.
Fun.
greg
