Sony KV-35S45 Timer/standby indicator is blinks.
Mike
Hi group!
Sony KV-35S45 TV has power up / power off, but has no sound or raster.
No other responds by remote control or by pressing any buttons (except
Power). Timer/standby indicator is blinks continuous once a second.
Filament is fine.
Any suggestions? Thanks. Mike.
Jerry G.
This can be a power supply failure on the main B+ to the scan
amplifiers, and or the horizontal output or vertical output stages has a
failure of one or more components.
Without references of power supply output voltages, scan supply
voltages, and scan drive waveforms, a simple diagnostics is very
speculative. Even then, without a hands on, and directly working on the
unit, it is hard to guess a cause over an email.
If you are not properly trained and equipped, I would suggest you give
the set out for an estimate. This will allow for an intelligent
decision about servicing it.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
Instruments http://www.zoom-one.com/glgtech.htm
Hi group!
Filament is fine.
Arthur Jernberg
Mike, the number of blinks indicate a general area to inspect. However this
is not for the novice to attempt. Cheers
