SOS : 4-bit binary divider circuit PLEASE!!!!!!!
K
kpk
Can anyone send me a 4-bit binary divider circuit in this email :
[email protected] ? I must make this homework for my university and i
am late.
I have to make this circuit only with NAND gates.
PLEASE HELP !!!!!!!!!
Thanks a lot
Charles M. Elias
am late.
Thanks a lot
Sorry,
I don't mind helping someone with homework if they have made a effort
and are stuck. I draw the line when the student submits nothing to
show that he/she has even tried to do the work. The purpose of school
is not to turn in someone else's work--what do you learn from that? I
also have to question the utility of assigning such a problem. I
think the professor is out of touch with reality or is a sadist.
Also, without considerable research, I cannot design such a counter
using only NAND gates--not that I would want to.
Charles
Jim Thompson
Sorry,
Charles
You can't? Sheeeesh! I'm an analog designer and I can. Ever heard
of master-slave. Takes 9 2-in-nands (one used as an inverter) to make
a D-flop.
...Jim Thompson
Peter Alfke
If your homework is too tough,
and the time just flies away,
thinking hard is not enough,
click: comp.arch.fpga.
There you find those friendly souls,
Austin, Philip, Peter, Ray
filling in your knowledge holes,
making problems go away.
But learning is for you to do,
even if it hurts the brain.
The one that has to learn is you.
There is no substitute for pain.
If you want to learn design
don't treat homework just as play.
Real life is not benign,
and you'll have to earn your pay!
sooner or later...
Peter Alfke
(originally posted a few months ago, but bears repeating.)
Peter Alfke
More constructively,
your professor wants you to:
1. realize that you need four cascaded flip-flops,
2. then "re-invent" the master/slave flip-flop,
which you can also find in old TTL databooks (7474).
Maybe an interesting learning experience,
kind of like the boy-scout test of starting a fire without matches...
Have fun !
Peter Alfke
Pete Fraser
I got thrown out for that.
Potassium Permanganate and glycerine which spontaneously
combusts and gets hot enough to light the Magnesium, which
is hot enough to light the thermite.
I thought it was impressive.
Mac
am late.
Thanks a lot
Everbody is assuming that this is a clock divider. But it could be an
arithmetic divider.
Just thought I'd point that out.
Mac
Luhan Monat
Hey, how about amonium-tri-iodide? 15 molar amonia and iodine crystals.
Make a slurry but dont let it dry out until you want it to explode.
(we had a lot of fun painting this stuff in dorm-room locks)
Ben Bradley
Jim Thompson <[email protected]> responded to a deperate
crosspost initiated by [email protected] (kpk) involving:
comp.lang.vhdl,
comp.arch.arithmetic,
comp.arch.fpga,
sci.electronics.design, and
comp.lang.verilog thusly:
An honest request for the answer to a homework assignment - I don't
think I've ever seen this before!
He learns, at a low level, how to cheat the system. Of course if
there's anywhere that the phrase "you're only cheating yourself"
totally applies, it's in school.
Perhaps it reinforces the concept that you can build any logic
device out of a sufficient number of NAND (or NOR) gates?
That's surely true of some professors, but how can you tell that
just from what the OP said?
As Jim said, it's not a big deal at all. Would you rather use
LM339's? ;)
a D-flop.
I don't know if I'd have the patience to spend three minutes doing
it when I know I could get a schematic that I could easily convert to
all-NAND-all-the-time off a (don't tell the OP) "d-a-t-a s-h-e-e-t" in
less time than that.
...Jim Thompson
Bonus question(s): How many 74(xxx)00's (quad nand gate) does it
take to make the 4-bit divider using Jim's solution, and why is "12"
an incorrect answer?
Brian Inglis
The establishment doesn't always like creative types -- did you demo
it or just explain it?
W
Wouter van Ooijen
How to be a manager?
I
counter? the OP asked for a multiplier. I could very well imagine
asking a sketch of a multiplier with an estimate of the amount of
gates involved. An easy solution would be a total 8->256 decoder
followed by a 256->5 encoder.
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
Tweetldee
Wouter van Ooijen
Ummm take a look at the subject line of this thread.. the OP asked for a
4-bit binary divider... 4 R-S flipflops in a chain.. no need for decoders
(or maybe I missed something in a later post).
Tweetldee
Tweetldee at att dot net (Just subsitute the appropriate characters in the
address)
Never take a laxative and a sleeping pill at the same time!!
W
Wouter van Ooijen
Sorry, I mixed multiply and divide :) But are you sure he meant a
clock divider? It could also be a binary ALU-style divider.
Wouter van Ooijen
http://www.voti.nl
DJ
am late.
Thanks a lot
If I were your prof, and I caught you blatantly trying to get others to do your
thinking for you, I'd make you design it using nothing but BC547's, resistors
and diodes. That way you might l-e-a-r-n something. That is why you are at uni?
dj
K
Kolja Sulimma
am late.
Your university probably has a synthesis tool for asics installed.
Just write your design in VHDL, remove all gates from the library but
the NAND gates and press the synthesis button.
Kolja Sulimma
Peter:
Applause for the poem....
Ben Bradley
In sci.electronics.design, [email protected] (Wouter van Ooijen
But you can do that with nothing but NAND gates, too. ;)
Jerry
WOW, your prof let you use NANDs? we had to do this using only
relays. Wish I had an easy prof like yours.
Jer
Bob Perlman
Jer
Hah! Luxury! When I was a boy, Professor Babbage made us use gears
and levers! Compared to that experience, designing with today's EDA
tools seems...well, pretty much the same, actually.
Bob Perlman
Cambrian Design Works
Spehro Pefhany
Bob Perlman
You had gears and levers? We would have given our right arms for gears
and levers! Cowrie shells was what we had, and were glad for it.
Best regards,
Spehro Pefhany
K
Keith R. Williams
Gag, spit, choke. Damn! Don't *do* that! Now I gotta clean of
my monitor, again.
