John Woodgate
- Jan 1, 1970
- 0
WOW, your prof let you use NANDs? we had to do this using only
relays. Wish I had an easy prof like yours.
You were allowed RELAYS? We had to use frogs' legs. And catch the frogs
first.
Hah! Luxury! When I was a boy, Professor Babbage made us use gears
and levers!
I read in sci.electronics.design that Bob Perlman
[email protected]>) about 'SOS : 4-bit binary divider circuit PLEASE!!!!!!!', on
Thu, 1 Jan 2004:
But I bet you enjoyed the tutorials with Lady Ada!
and levers! Compared to that experience, designing with today's EDA
tools seems...well, pretty much the same, actually.
Bob Perlman
Cambrian Design Works
thinking for you, I'd make you design it using nothing but BC547's, resistors
and diodes. That way you might l-e-a-r-n something. That is why you are at uni?
DJ said:An analytical deduction?
Why would he need diodes?
Wouter van Ooijen
Can anyone send me a 4-bit binary divider circuit in this email :
[email protected] ? I must make this homework for my university and i
am late.
I have to make this circuit only with NAND gates.
PLEASE HELP !!!!!!!!!
Thanks a lot
You had gears and levers? We would have given our right arms for gears
and levers! Cowrie shells was what we had, and were glad for it.
Best regards,
Spehro Pefhany
Here is a divider using pots.
http://w1.859.telia.com/~u85920178/index.htm
look under "useful circuits" then "simplist computer"
Tom said:In John Crighton typed:
I can't find those links on the site.
In comp.arch.fpga Wouter van Ooijen (www.voti.nl) said:Why would he need diodes?
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
You still don't need the diodes - it's wired-or logic.Wing Fong Wong said:That would be diode transitor resistor logic, stuff from 1st year electronic
engineering. Diode and resistors to make and gates and transitor invertors.
Bob said:Hah! Luxury! When I was a boy, Professor Babbage made us use gears
Bob Perlman
am late.
Thanks a lot
Ken
YD said:But the OP wanted to use only NAND gates. Oh well, an inverter on each
input will turn an OR to a NAND, and as we're already spending
transistors by the bucket might as well go for it.
Easier than that, just define Vcc(ish) as 0 and ground(ish) as 1.
Paul Burke
