jasonEE said:
I have some questions about this circuit:
1) what are the transistor used for ???
2) how to evaluate the value when the light 10th is on ???
3) the range for measurement is from 0db to 30 db ????
The text of my project answers your questions:
"4) Three 2N3904 transistors are used as emitter-followers:
a) Q1 is inside the negative feedback loop of the 2nd opamp as a voltage reference for the other two transistors. Hopefully the transistors match each other.
b) Q2 emitter-follower transistor quickly charges C8 which discharges slower into R13 and is used as a peak detector.
c) Q3 transistor is the automatic gain control. It is also a peak detector but has slower charge and discharge times. It drives the comparators’ resistor ladder in the LM3915 to determine how sensitive it is. R15 from +5V is in a voltage divider with the ladder’s total resistance of about 25k and provides the top of the ladder with about +0.51V when there is a very low sound level detected. Loud sounds cause Q3 to drive the top of the ladder to 5.1V for reduced sensitivity."
The 3rd transistor provides automatic gain control so the max indication of the LM3915 is increased from 30dB to 50dB. Because of this AGC you don't know what is the actual sound pressure, but the LEDs always indicate without staying at the end of the scale during loud sounds.
The actual sound pressure level for quiet sounds depends on the sensitivity of your mic. My mic is very small from a cell phone so maybe is not very sensitive. I designed the gain of the circuit to be high enough so it indicates on a few LEDs a pin dropped on the floor a few meters away and people whispering about 3m away. I didn't measure the actual sound pressure levels.
