They say how to connect the Mode pin 9 of the first LM3915 to pin 1 of the second LM3915 and a resistor across LED #9 for Dot mode. For Bar mode then leave both pins 9 disconnected.jon said:OK but the datasheet shows how to cascade two LM3915 in Dot Mode, does that mean the I can't change the mode to bar after?
They show a reference voltage of 10V so the LM3915s should have a 12V supply. But then a power resistor would be needed to reduce the power dissipation in the LM3915s in the Bar mode.And if I cascade two LM3915, can I still use the 9V battery or should I change it with something with a higher value? I think I'll just keep it like it is for now...
Go to www.farnell.com and look to see if they have an office in your country and have the IC.... it seems that MC33172P is hard to find in my country.
Is there a good alternative to MC33172P?
The MC33172 has two of the opamps of an MC33171. An MC33174 has four of the opamps. The opamps are the same. The datasheet shows the different pin numbers.Also, MC33171 and MC33174 are available. When I searched the datasheet, they have the same. Are they different? Can I use any of those 2 as an alternative? (Sorry, I'm new to these stuff)
