spice: ideal transformer
Michael Zedler
I've google/google groups'ed a bit but anyhow I cannot make an *ideal*
transformer to work. The file
ideal transformator
..control
ac dec 20 1k 1g
plot vdb(3)
..endc
..subckt transformer 1 2 3 4
vsense 1 2 dc 0
e1 1 2 3 4 1
f1 3 4 vsense -1
..ends
v1 1 0 dc 0 ac 1
r1 1 2 10
X1 2 0 3 0 transformer
r2 3 0 1k
..end
makes Macspice hang... Please note that for my purpose I cannot use 'K'
coupled inductors. DC behaviour of the ideal transformer is of no interest.
Cheers,
Michael
Tom Bruhns
vsense 1 2 dc 0
e1 1 2 3 4 1
f1 3 4 vsense -1
.ends ....
Cheers,
Michael
OK, let's look just at the transformer. You have a short circuit (a
DC voltage source set to zero volts) across nodes 1 and 2. And you
have a dependent voltage source e1 which is also across those
terminals. It is not a good idea to put two voltage sources in
parallel. I would suggest you try putting them in series. Does that
help? Then you can have a primary (1-2) voltage controlled by what
the secondary voltage is, while still using vsense to sense the
current in the primary.
Cheers,
Tom
H
Helmut Sennewald
Michael Zedler said:
ideal transformator
.control
ac dec 20 1k 1g
plot vdb(3)
.endc
vsense 1 2 dc 0
e1 1 2 3 4 1
f1 3 4 vsense -1
.ends
v1 1 0 dc 0 ac 1
r1 1 2 10
r2 3 0 1k
.end
interest.
Cheers,
Michael
Hello Michael,
It looks similar to the ideal transformer from this article.
http://www.elecdesign.com/Articles/Print.cfm?ArticleID=6204
I have made a subcircuit from this example:
Plese change the voltage ratio "10" to the desired value.
For a 1: transformer replace the 10 by 1 and the -10 by -1.
* prim: (+)1 (-)2
* sec: (+)3 (-)4
* ratio Vsec/Vprim = 10
..SUBCKT TRAFO 1 2 3 4
F1 1 2 VSENSE -10
E1 30 4 1 2 10
VSENSE 3 30 0
..ENDS
Best regards,
Helmut
PS: If you have some kind of Windows emulator, you could try LTspice.
It also runs with WINE in Linux. LTspice has a state of the art graphical
interface for schematics and waveforms.
http://www.linear.com/designtools/software/switchercad.jsp
http://tech.groups.yahoo.com/group/LTspice/
A full blown version of the ideal trafo with parameter passing for LTspice
* prim: (+)1 (-)2
* sec: (+)3 (-)4
..SUBCKT TRAFO 1 2 3 4 N1={N}
* N1 = N = Vsec/Vprim
F1 1 2 VSENSE {-N1}
E1 30 4 1 2 {N1}
VSENSE 3 30 0
..ENDS
How a netlist for a TRAFO-instance could look in LTspice:
XU1 10 0 50 0 TRAFO N=1
Normally one would use a symbol in the schematic of course.
Symbol file, name it trafo.asy
Version 4
SymbolType BLOCK
RECTANGLE Normal 80 64 -48 -80
TEXT -22 -48 Left 0 TRAFO
WINDOW 39 17 24 Center 0
SYMATTR Prefix X
SYMATTR SpiceModel TRAFO
SYMATTR Description Ideal Transformer
SYMATTR SpiceLine N=1
PIN -48 -64 NONE 8
PINATTR PinName 1
PINATTR SpiceOrder 1
PIN -48 48 NONE 8
PINATTR PinName 2
PINATTR SpiceOrder 2
PIN 80 -64 NONE 8
PINATTR PinName 3
PINATTR SpiceOrder 3
PIN 80 48 NONE 8
PINATTR PinName 4
PINATTR SpiceOrder 4
joseph2k
Michael said:
ideal transformator
.control
ac dec 20 1k 1g
plot vdb(3)
.endc
vsense 1 2 dc 0
e1 1 2 3 4 1
f1 3 4 vsense -1
.ends
v1 1 0 dc 0 ac 1
r1 1 2 10
r2 3 0 1k
.end
How very strange, i am used to making ideal and real transformers with an Lm
term coupling "normal" inductors. Almost sure to be a better simulation of
any possible real circuit.
Michael Zedler
F1 1 2 VSENSE -10
E1 30 4 1 2 10
VSENSE 3 30 0
.ENDS
Works like a charm, thank you!
Michael
Michael Zedler
In most cases your statement may be correct, but not for this one:
Joint simulation of some lumped elements together with a distributed
microwave circuit (the latter represented by a canonical Foster
equivalent circuit which requires ideal transformers).
Michael
joseph2k
Michael
OK. What is going on with the Foster equivalent circuit that normal Lm
ideal transfromers will not work.
Michael Zedler
An ideal transformer is needed; no parasitic inductance, coupling of 1.
Again, this is an *equivalent* circuit. It models the distributed
circuit. And if non-ideal transformers were used essentially the
transfer function of the destributed (physical) (multiport-)circuit were
altered.
Michael
joseph2k
altered.
Michael
OK, i do not understand "parasitic inductance" in this context. I have a
little experience (near trivial) with "transmission line transformers" in
PWB and MMIC arenas. Please elucidate.
joseph2k
In the meantime i did some googling on Foster equivalent circuit. Wow, was
i ever on the wrong track. Not only was my suggention of using standard Lm
terms waste lots of simulation time to no good; it would actually
completely destroy the integrity of the simulation.
I have to admit though that the basic idea is wonderful, it makes analysis
of something wierd like a fractal antenna doable.
