Re: LT Spice ideal diode
Martin Riddle
John Larkin said:
Never mind, I figured out the ideal diode.
Click the D thing and add a diode to the schematic. Rename it Didl.
Then add a spice directive string nearby...
.model Didl D(Ron=0.1 Roff=1G Vfwd=0)
with whatever values you think are close to ideal. For some reason, my
sim slows down if I use too low an Ron value. The 0.1 is good enough.
The ideal zener is then just a voltage in series with this diode.
I'm doing what the controls guys call a "high select", to create a
voltage that's the greater of two inputs, to switch my power supply
from constant-current to constant-voltage mode. I did a clever thing
with two switch elements, but it did funny things sometimes and was
too hard to think about.
John
Someone has a patent on I think its on the fly C-mode to V-mode
switching, you might want to look that up.
Hint, they are on LI NY.
Cheers
H
Helmut Sennewald
About LT Spice: where the heck is the "draw" menu? And why does it
keep moving my schematic around in the view window, jamming it against
the left and right edges at random?
John
Hello John,
This "draw" menu is in
Edit->Draw
You can switch off the automatic scroll-view in the
Control Panel -> Drafting Options
Best regards,
Helmut
