Square wave input, PWM output?
rsajan1
Nov 3, 2009
Hi folks,
I'm trying to find an IC or simple circuit that gives a pulse width modulated signal for a DC voltage input. For example, the input to this would be a square wave alterating between 0 and 5V. When the input is 0V, the output is 0V but when the input is 5V, the output should be a 0-5V square wave with a controllable frequency.
The input comes from a comparator, maybe there are comparator ICs that have this as an in-built function? I cant seem to find any.
Thanks!
rob_croxford
Aug 3, 2010
262
Do you want to vary the Frequency or the Duty cycle?? PWM is generally a variance in duty cycle to control the gate pin of a swtiching device, for instance. Or it can be used to vary the direction of a servo motor...
What is your application?
Hi folks,
Thanks!
This is contradictory. An input cannot be a DC voltage AND a square wave.
