K
kell
- Jan 1, 1970
- 0
I was looking at this guy's voltage regulator
http://homepage.sunrise.ch/mysunrise/joerg.hau/mot/voltreg.htm
T1 acts as a comparator with positive feedback through R4 for
hysteresis. To eliminate oscillation, he adds the capacitor C1.
"Capacitor C1 stabilises the circuit at higher load. I have observed
that the switching behaviour of the circuit
without this capacitor is pretty "sharp" and stable if the load draws
less than ca. 0.5 A (typically); however
at higher current I observed a tendency to oscillate. This can be
observed best with an oscilloscope,
or a 12 V lamp as load: it will start to glow, instead of being
switched completely on or completely off.
C1 eliminates this instability"
I built a voltage regulator using that circuit and it works. It does
oscillate without the cap, and installing the cap
in the circuit prevents the oscillation.
I was wondering if I could use the same strategy with a comparator.
I have a project where a comparator will have high impedance,
slow-changing inputs, so I'm
concerned about oscillation.
I was skimming through the National Semiconductor datasheet for LM*111
comparators and they showed a couple of strategies
for preventing oscillation, but no cap from the output to the negative
input. Is there some reason it wouldn't work on a comparator?
I'm actually going to be using LM2903.
