stabilizing the DC output of a cheap mig welder?
I bought one of those cheap chinese mig welders, It splatters alot and
is alittle unstable. I
removed the case to find only a transformer and two diodes. Im
thinking of adding a inductor
in the + dc line, most good dc welders have atleast this. Is there any
other improvements
i could do to stabilize the output? Would filter caps help?
John Popelish
other improvements
A capacitor would make the spatter worse (big changes in current for
small changes in arc resistance). I think an inductor is a fine idea.
It tends to keep the current stable over a half cycle, even if the
arc is shorted momentarily by a drop of molten metal.
I added one to my buzz box and it allowed me to do some very nice
welds on thin material at low current. It takes some big wire,
though. I used 1/8" by 1/4" wire for mine.
I
Ignoramus21405
John, how did you make the inductor?
i
John Popelish
I can't remember exactly where I got the laminations, but I had a
stack of E's about 4 by 6 inches in size. I made two stacks about 2
inches high and epoxied the laminations together. Then I drilled a
pair of quarter inch holes near the ends of the center legs, to make a
section that would saturate first, so the inductance would sag,
gracefully as the core approached saturation flux.
I made a wooden coil form with a block the size of the center of the E
stacks with sides bolted on. I premeasured a length of 1/8 by 1/4
wire and placed the middle of the piece along the bottom of the form,
and would two coils, side by side, so the ends were on the outside. A
made 6 or 8 of these coils and bound them with glass tape and epoxy.
I placed either 3 or 4 of these coils on the center leg of each E
stack, with a quarter inch of space between the stacks for cooling. I
overlapped the adjacent ends of the coils and soldered then in series
(one set on each E stack, so I could connect the halves in series for
low current, or parallel for high current).
I put the open ends of the E's together on a 1/8th inch spacer (just
sat on on top of the other). I hooked the two halves in series, used
the inductor for some low current work, and have never tried it with
the parallel connection. I do very little thick section welding. I
made this 15 or more years ago, and have since collected an inductance
bridge. One of these days I should measure what I made.
I have one kind of rod (I don't remember exactly what they are) that
blast molten iron and slag all over the place when used with AC, but
with DC and this big inductor, I get very smooth welds covered with a
puddle of slag that slowly curls up at the ends and falls off the
weld, as the metal cools. Almost as little clean up as if I were
using a tig torch. The neat thing is the sound the inductor makes
each time a drop of molten steel bridges between the electrode and the
work. Instead of the pops with metal splatter and flux all over, the
inductor just gives off a brief "unng".
John Crighton
other improvements
Hello Mr Tucker,
I have been down a similar road, buying a cheap
welder and then trying to make it work better
by doing the sort of improvements that you are
talking about. I wasted a lot of time and effort.
My advice to you is take it back and spend
more money on a machine similar to these
in this link below
http://www.ben.com/tools/sp-175plus.html
Stay away from 115V machines. Too small.
Here is the link to the Lincoln 175T manual.
http://content.lincolnelectric.com//pdfs/products/navigator/im/IM537D.pdf
Page 54 shows the transformer and choke assembly
made with flat ribbon wire. You can see the capacitor
also. These 93,000 microfarad caps are very expensive.
About $100 as a spare part here in Australia.
Maybe cheaper in your part of the world.
Schematic is on page 43
What I like about this model, if you look at the
schematic, is the voltage taps are done on the
secondary of the transformer. A cheaper, not so
good method, is to tap the primary winding of the
transformer.
Here is a link to the Miller 185 manual
http://www.millerwelds.com/om/o1313p_mil.pdf
Page 38 shows four capacitors of 30,000 microfarads.
Four separate caps is better than one big cap.
Lower ESR
The schematic is on page 24.
From the schematics of these manuals, you may get
some ideas what to aim for if you do decide to try and
improve your cheap welder. There is also a how to
weld tutorial and problem solving pages that may
help with the spatter problem you are having.
Another option is to use your electronic repair
skills to fix a broken machine or a machine that
has been written off beyond economic repair
because some component is no longer available.
Use you skills, get round that problem and maybe
pick up a bargain on an older high quality machine.
Just for fun on your cheap welder. Try adding
a choke to the "work" lead. You don't even have
to cut the work lead. Just connect the large alligator
clip/clamp (that normally goes to the job) to
the "add on" choke and use another "work clamp"
from the choke to the job.
You can make a choke. Make two or three.
Find some old discarded microwave ovens.
Salvage the large power transformer.
Remove the "I" piece of the "E" and "I' core.
and knock the windings out of the "E" section
of the core.
To remove the "I" section in one piece.
Slightly hacksaw about 1mm into the weld.
Use a "brickies bolster" or wide blade chisel
and gently tap into the hack sawed cut.
The "I" section will come off easily in one piece.
It would be nice to use proper winding wire or
ribbon but just for fun use whatever heavy insulated
cable you can get your hands on and fill up the
window. Probably only several turns.
There has to be a gap between the "E" and "I"
pieces of your core. Start with an excessive gap
of say 2 to 3 mm and use whatever clamping method
you like to hold the "I" piece in place.
Tack weld it back on if you like, or get fancy and
make it adjustable with brackets and screws.
Make a few chokes like this and you can experiment
adding one or all three to the "work" lead and see
if your welder works better.
Later on you can adjust the gaps of your chokes
a bit nicer to get maximum inductance for the
operating current you are interested in.
No point in having a huge gap where the choke
does not saturate until 200 amps flows through it
when you are only interested in say 100 amps.
No Point in having a small gap and the choke
saturates with only 30 amps flowing through it.
So while you are just experimenting for fun, err on
the big gap side. Then close it up later.
Some time ago, I was sucking the brains of an
engineer from Lincoln Electric in regard to building
chokes and how to set the core gaps and he got
the shits with me and said,
"We make fucking welders here, not electronic
power supplies, we experiment by trial and error
until the machine welds correctly"
So from the horses mouth, experiment and have fun. :)
I enquired on this group years ago about setting
the gap for a particular current. There were a few
methods involving power supplies/banks of capacitors
and using an oscilloscope to look at the pulse shape
across a low value sense resistor. I didn't quite
understand what I was supposed to look for.
This was the other method suggested which I used to find the
current at which the core saturates with a particular gap.
Variac on very low setting (several volts) ? AC stick welder primary
Welder O/P --> 100 amp shunt --> choke under test --> Welder O/P
That is, across the welder output terminals connect your choke
under test in series with a 100 amp shunt.
The 100 Amp shunt acts as a sense resistor so a digital voltmeter
can indicate the current flowing. For example on my shunt 60mV
equals 100 Amps.
An oscilloscope is placed across the shunt and shows a nice sine
waveform.
Turn up the variac on the primary side AC stick welder.
Warning! Keep input voltage low, several volts only, because
the secondary has almost a dead short across it.
As the current increases through the choke and shunt you will
see the AC waveform begin to distort slightly.
Note what the current is just before distortion.
If it is around 100 amps you are laughing.
If it is only 40 amps then you will have to increase the gap
between the E and I piece and try again.
I'll bet this machine of yours does not have
a proper wire speed controller that works
independent of the output voltage settings.
This is another improvement you can make.
Pulse Width Motor Speed controller. Google for those.
Here is the one I used. It works well.
http://www.solorb.com/elect/solarcirc/pwm1/
Be warned, I spent more time experimenting/making
test welds trying to improve a cheap machine than
I did welding up proper jobs and projects.
The cheap welder improvement project takes over.
Isn't that correct Igor?
Home built Welders become an Obsession! :)
Regards,
John Crighton
Sydney
Rick
A MIG welder is designed for constant voltage, not constant current. The arc length
becomes self regulating becasue small changes in voltage cause a large change in current.
Having said that, variable or fixed inductors can be found in some MIG machines to reduce
splatter.
John Popelish
splatter.
I can see how real current regulation would ruin the automatic arc
length feedback needed for stable MIG welding. So the optimum
inductance for a MIG welder may be lower than for a stick welder.
Rick
Yes, you're probably correct. And as this is a cheapo unit I don't suppose it has any
provisions for setting an output voltage, just wire speed. Not a whole lot to lose by
trying one, that's for sure...
Thanks for all the replies, i found a junked 3 phase dc welder and
salvaged a stack of three inductors, they dont look that big
so i guess it dosent take as much inductance to filter 3 phase as
single phase. I plan on trying one then series adding two
then three to get enough inductance. My question is can i put the
inductor in the ground lead or do i have to put it in the hot
lead. I have a 225 amp buzzbox for heavy stuff, i got this cheap Mig
to help with thin metal. It doesnt have a wire speed control
just a Hi/Lo switch so i also plan on adding a reostat to help control
wire speed.
I
Ignoramus16356
wire speed.
How about changing a plan and restoring the junked 3 phase welder?
Depending on how good it is, it could be a great welder!
I also have a 3 phase dc welder:
http://igor.chudov.com/projects/Welding/00-Hobart-CyberTig-Welder/
i
John Crighton
Yes experiment with various combinations.
My question is can i put the inductor in the ground lead
or do i have to put it in the hot lead.
Electrically it makes no difference.
Much easier for you to simply add your experimental
chokes to the the "work lead" ouside the case of
the welder. (Lets call it a work lead incase pedants
get upset and start panicking ;-)
WoW! Is this a three phase machine.
i got this cheap Mig to help with thin metal.
I did the same thing also but my elcheapo mig
was useless on carbody thickness as well as
1/8 of an inch thickness for general purpose.
After mods, concentrating on car body thickness
only of around 1mm or 40 thousands of an inch
my modified mig works well compared to a
good brand welder such as Lincoln 170T on
car body thickness.
I used the existing choke in my cheap mig welder
as a choke input filter DC supply. I added 60,000
microfarads of capacitance in a separate external
capacitor bank outside the welder. This made
for a stiffer DC supply. I mean a supply with better
regulation. I hate to use terms like regulation when
we are talking about crap but you get my drift.
Because the DC voltage I have to work with is
now well below what it used to be due to the choke
input filter, thin metal such as car body stuff is all it
can do. But the voltage on this DC supply is better
regulated, stiffer, better stabilised, use whatever term
you like, better welds are now produced.
Heaps better and that nice crackle fried bacon
sound is produced. Not a hissing spluttering noise
that it made before while running a bead. Beads
that melted right through and almost fell out the
bottom. Now the weld bead looks more like
the tutorial manuals and I don't burn through
as easily as I did before.
But I had to have another choke This is the
choke that makes the mig welder work as a mig
welder. The choke that you have to have.
And you say your machine is so cheap that it doesn't
have a choke at all. Incredible!
For me this choke is simply added to the work
lead outside the case of my cheap welder. There
is no room inside the case. I just experimented
until the magical crackling sound was obtained.
It doesnt have a wire speed control just a Hi/Lo switch so i also
plan on adding a reostat to help control wire speed.
In my cheap Mig welder, I measured the highest DC
voltage that was applied to the motor about 30V.
That is with welding wire running out of gun but not welding.
While welding the voltage on the motor was all over the
place jumping above and below 12V so the wire speed
was varying greatly.
This is a bad ... bad .... bad...
I built my wire speed motor control box external
to the welder on a long cable so that I can have
the control box near my left hand so that I can
adjust the wire speed knob while welding.
To get that magic crackling noise.
This box contains a small power transformer for
a 2 amp DC regulated supply of around 22V DC.
Just turned out that way because that is what I had
to hand.
This speed control I told you about earlier works nice.
I added a delay circuit also. Motor starts a few second
after the trigger is pressed to make sure shielding
gas is well and truly flowing. Didn't make a lot
of difference but I liked the idea and did it for
fun. I added a relay to short out the motor connection
terminals after the power is removed from the motor.
This is electrical braking and it did work, so I now
clip off one inch of protruding wire off the end of the
gun nozzle instead of two inches, before making
a new weld. The real welders have a control
called "burn back" which saves wasting wire by having
to clip so much off the end of the nozzle. You should
still clip the wire anyway before continuing the bead.
The sharp point helps make a good quick starting arc.
Anyway this "burn back" control just delays the
power being removed form the gun after the trigger
has been released. Motor speed runs down and
welder keeps welding for a small preset time to
use up the wire.
I think you would waste a lot of time trying to find
a rheostat, It would be expensive. Then you still
have a motor that varies in speed while welding
because your motor is running off the welders
output supply. You are only slightly better off.
Your cheap mig welder sounds crappier than
mine was. Mine had a choke and a crappy
speed control you have less to play with.
Built a proper pulse width modulation motor
controller. It is easy, cheap and will work nicely
straight away with no messing around.
You would have to buy a bunch of 10 watt or
20 watt 2 amp rheostats to find one of the
correct value to put in series with the motor
to get the required motor speed. Bad idea.
Lets hear how you got on with the chokes
that you found. I am keen to know.
Regards,
John Crighton
Sydney
I have a problem with my inductor, its a high current RF choke made
with # 6 or 8 square copper wire (same size as the round alum wire on
my transformers output so i know its heavy enough) however its air core
so i need to add some kind of core to raise the inductance. The
problem is its 2" I.D. is round, i cant think of a core except for a
solid steel rod, or stack ( I ) sections in it from a old transformer,
i thought of making a pvc donut from elbows and filling with steel BBs
sense i dont have powdered iorn.
Second its hard to insert the choke in the hot line going to the migs
flexible feed hose, so for experimenting would it be the same if I
put the choke in the ground lead ?
GregS
I bought some powerded iron some time ago for doing a similar
thing. It may have been Edmunds Scientific. Best to try to partially insulate
the particles.
greg
Don Lancaster
The core will likely saturate, causing all sorts of problems.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
John Popelish
You might put a stack of ferrite beads in the middle of the coil, like
the LFB360230-200
http://www.digikey.com/scripts/DkSearch/dksus.dll?KeywordSearch
Or the wound ribbon core from a soldering gun.
That puts more voltage on the work piece.
