Stage Line 500W amp repair project
WHONOES
May 20, 2017
1,242
Looks interesting. If it's a free download then give it a try. If it's not what you want you can uninstall it and you have lost nothing.
Have a go!!
bikemech
Oct 23, 2014
456
I have downloaded it already, thats it on my laptop, thinking i can butcher a pair of headphones with a mic to make some leads, i am guessing it would only be 1 input chanel that the mic would normally use, any ideas on that ?
bikemech
Oct 23, 2014
456
Also has a sig gen built in that seems to work ok, i wonder if i could use the ear piece lead as the sig gen
bertus
3,875
Have a look at the specs of your sound card.
The circuit in post #429 has 5 V zeners to limit the output, but that may be to high for the sound card.
Bertus
bikemech
Oct 23, 2014
456
Bertus
I have no idea how i would find that out, i do understand there has to be some protection/current limit for the input on the MIC side, is that what that circuit was for in post #492 ?
Pete
bertus
3,875
I have the number wrong, it is post #479.
It is made by Wendy (william before his transition).
Does the card have a line input?
That can handle more than a MIC input.
Bertus
bikemech
Oct 23, 2014
456
Bertus
Hi, all it has is a headphone socket, but also works headpbones with a MIC if that helps,
Pete
bertus
3,875
Is it the input of a laptop?
Wich brand and type is it?
Bertus
WHONOES
May 20, 2017
1,242
bikemech
Oct 23, 2014
456
I assume the input to your sound card is via a 2.5 or 3.5mm jack. Ideally you would use some screened cable to make up and input lead.
Another alternative would be to use a BNC to 2.5mm jack plug that you can plug into your sound card and then you can use a regular scope lead with attenuators. See link below. You may be able to use them for the Sig Gen as well.
Pack of 5 BNC Female Jack to 2.5mm Plug RF Coax Adapter: Amazon.co.uk: Computers & Accessories
Ahhhh, fantastic idea !!!, thanks @WHONOES i will look into that, would be much easier, would i still need some form of protection circuit so as not to overload the sound card, or is this built into the probes ?
Pete
bikemech
Oct 23, 2014
456
Just looked, that may not be possible, the BNC only has 2 points of contact, my headphone with MIC has 4,
Pete
WHONOES
May 20, 2017
1,242
The probes will have attenuators in them. You can get them with 10:1, 100:1 or 100:1 all usually switchable between straight through and attenuated. If you can find some relatively cheap ones then buy a selection, it will save having to cobble together and calibrate your own.
It would also make sense to find out the input conditions of your sound card. If it is just a Mic I/P then it is probably quite sensitive. Some have Mic and Line I/P's.
WHONOES
May 20, 2017
1,242
Ok. Just seen you Pics. Does make thing a bit more difficult. I suspect you would need to separate the input and output into 2 distinct circuits. You could break it out into a small Plastic or Ali' box with 2 BNC sockets in it.
I assume the Sig Gen is output via the headphone O/P?
WHONOES
May 20, 2017
1,242
Just seen you suggestion in #496. I think you would be better off sorting out which wires are which and going the route described in #497.
You also have to consider keeping the input screened which is best achieved as described.
bikemech
Oct 23, 2014
456
Yes it is, sig gen output is via the LH earphone
