Skybuck Flying
- Jan 1, 1970
- 0
I am taking it very slow with re-building my PC and thinking and checking
about everything, every little detail gets examined.
I was just cleaning the dust filters and noticed some water vapor on the
center or so... I started to wonder if they are perhaps obstructed by "white
stuff in the water".
So I started blowing against the dust filter and keeping my hand behind
it...
I didn't feel much airflow go through so I thought "that's odd".
Then I started blowing more focusedly and still very little airflow went
through it...
Then I removed the dust filter and blew directly towards my hand ! It felt
very cold and strong... then I placed dust filter back and almost nothing.
So the dust filter is actually blocking 70% to probably a more realistic
percentage of 90% of airflow !
No wonder the fans have to spindle at medium to keep it cool and it still
barely keeps cool. (Motherboard 45 degrees or so)
I received an e-mail from somebody asking and wondering how a big case like
antec1200 could possible still overheat a system.
Well the answer my dear is a very simple answer:
"The antec 1200 dust filters block 90% of the airflow !".
This is very counter productive because now I have to set the airfilters to
medium (double speed) it sucks in more dust, so filters get filled sooner.
Ultimately I suspect the dust filters don't help much at all... and dust
still gets sucked in from all kinds of corridors and such.
So I am going to do more experimenting with this case.
This time I will leave the dust filters completely out and I will run it at
low settings.
This will probably cool everything inside with ease... also less dust will
be sucked in and low noise, though I always have airplugs in anyway.
This is also better for back and top airfan otherwise they also getting
dusty.
Hopefully this won't turn my PC into a vacuum cleaner... but it's worth a
try !
=D
(I think it will be less than previously because the dust was insane !
Bye,
Skybuck.
it...
through it...
low settings.
dusty.
try !
Bye,
Skybuck.
