stepper driver help!
So I've designed a translater using basic 74 series ttl gates. I've
designed both a half and full step translater. I finished soldering
together the parts and i tested out the four outputs and the full step
sequence was correct. However I hooked up the outputs to a ul2003
darlington array chip to the stepper motor and it would not move at
all.... I probed the inputs and it looks like the translator output is
greatly attenuated. is there a way to keep the origial signal without
attenuating? could i just use a 7407 buffer between the driver and
translator?
Chris
translator?
The ULN2003 darlington array is made to sink current. It needs a power
source. If you've got a unipolar stepper with 6 or 8 wires, your
wiring could look like this (view in fixed font or M$ Notepad):
| VCC VCC
| ___ | ___ ___ | ___
| .-UUU-o-UUU-. .-UUU-o-UUU-.
| |2/7 ULN2003| |2/7 ULN2003|
| O O O O
| (___) (___) (___) (___)
(created by AACircuit v1.28.5 beta 02/06/05 www.tech-chat.de)
It might help if you describe your stepper motor. Voltage, current
requirement, how many wires (4, 6, 8).
Good luck
Chris
Spehro Pefhany
greatly attenuated.
Can you put a number on "greatly attenuated"? A 74xx series TTL gate
should be able to drive a ULN2003 with no problems (to a couple
hundred mA output current anyhow). The input voltage will drop a bit,
but probably still more than 2.5V. Are you pulling the supply down?
translator?
Best figure out what you are doing wrong first.
Best regards,
Spehro Pefhany
Robert Baer
Best regards,
Spehro Pefhany
I have not looked at the scnematic of that driver, but...
*If* it is nothing more than a number of darling transistors (as
mentioned) and if the emitters go to ground, the bases will not go above
(roughly) 1.3V - which is significantly less that an OC TTL output,
hence the term "attenuated".
Maybe that severe load over-stressed the TTL and so now cannot drive
the bases enough to "saturate" the darlingtons?
