stepper motor problem!!!
maham ahmed
Jul 7, 2014
10
hi every1 ! i was driving a stepper motor ....few days ago the motor was in working condition although there were vibrations in it but it was in working condition....but today when i checked it it is not even rotating on the same program....i have checked properly the internal wires ..all is fine .Then i checked stepper motor through battery method i hope u know the battery method that is just give ground to common and 1 by 1 give 5v to all the wires of motor ..it will take jerk and step....so when i checked this today i was very surprised to observe that at 1 time only 2 wires is taking jerk and step....that two wires are not fixed when i checked it several times the wires which were taking jerk were different.
i dont know what is happened and i am very worried about this problem.what does it mean ?plz help me out
Gryd3
Jun 25, 2014
4,098
Maham,
To confirm, what you have found with the battery method is that 2 of the 4-wires work on your initial test. As you kept testing however, you have found that the two wires that work are now different.
With the wires disconnected, can you please measure resistance from common, to each of the 4 leads?
maham ahmed
Jul 7, 2014
10
Maham,
yes i have checked the resistance....the res between common with each lead was about 1.5 ohm... and between the leads were half of this resistance
maham ahmed
Jul 7, 2014
10
Gryd3
Jun 25, 2014
4,098
Can you please double-check these measurements?
If common to one lead was 1.5Ω, in theory lead to lead would be 3Ω
Gryd3
Jun 25, 2014
4,098
Also, I realize the time of computers allows you to get answers from anywhere 'arshia', but when you post the same question on multiple boards it can really complicate things. You will need to follow many more trains of thought in troubleshooting the same issue, and it's much more difficult for us to help when we don't know what else you are trying to or are told to do from other sites.
(I have also found posts on yahoo and allaboutcircuits.com)
maham ahmed
Jul 7, 2014
10
no According to theory the lead to lead res would be half of the res of lead to common res
maham ahmed
Jul 7, 2014
10
because we can't rely only onn 1 forum as answers in any forum are not always correct...people just share their experis and opinions.
Interesting theory.
ahmed, I propose that you stop posting here until or unless you find your problem cannot be solved elsewhere. It will be more economical on your time and ours. As Gryd3 points out, fault finding is best done by following a structured path, not by going scatter-gun at the problem.
Find someone you trust and follow their advice to try to track down the problem.
