(sub) miniture LCD
ChronoFish
Hi there,
I'm looking for a VERY small 1 line LCD display - approximately 9 chars long.
Size of the digits should be no larger than 6mm and would prefer something on the order 3 mm. No backlight - prefer black on grey.
Thanks!
- CF
W
Wim Ton
long.
Salvage one from a calculator.
Wim
ChronoFish
Wim
This seems easier said than done. That is exactly what I tried to do - but the connection point is pretty funky - some sort of
conductive rubber that lays on the PCB. While intriguing and fun to play with - I need something a little more robust to mount in
my case. It is about the right size though.
Any other thoughts?
Thanks!
CF
John Woodgate
I read in sci.electronics.design that ChronoFish <[email protected]>
wrote (in <ZMdUb.11338$Ii2.6812@lakeread03>) about '(sub) miniture LCD',
but the connection point is pretty funky - some sort of conductive
That's how they normally are connected. The idea is to mount the device
resiliently and without any bending force developing.
need something a little more robust to mount in my case. It is about
The conductive rubber connectors are quite robust (think of the hard
treatment calculators often get) but the mounting does need some careful
dimensioning.
Phil Hobbs
dimensioning.
Right, plus the brittleness of the glass and the size of the CTE mismatch
with FR-4 board causes massive breakage or peeling of the metal pads under
temperature cycling.
Cheers,
Phil Hobbs
IBM T. J. Watson Research Center
Yorktown Heights NY 10598
BobGardner
That's a 'zebra strip'. I've had buffalo burgers and clam strips, but those
zebra strips are tricky....
