: M Kiviranta wrote:
: > Not relevant to the original question, the integration constants (equal to
: > trapped flux) should additionally be integer multiples of the flux quantum,
: > 2.07E-15 webers.
: Is that really true? SQUIDs may constrain the flux through them to some
: integer multiple of 2e/h, but is it the same for a continuous superconducting
: loop?
I think so. A mere perfect conductor can trap an arbitrary amount of
flux (flux changes are prevented by screening currents which arise
in the loop), but for a superconductor the trapped flux is a multiple
of the flux quantum. The reason is that the mechanism behind superconductivity
(when contrasted against a hypothetical *classical* mechanism giving rise to
zero resistivity) requires the quantum phase of the electrons (more
accurately: phase of the order parameter of the condensate) to change
by an integer multiple of 2pi radians when traversing around the loop.
Thus even the flux threading an enormous persistent current magnet (like
an MRI magnet or a fault limiter) should consist of an integer number of
flux quanta, however enormous the number might be.
It is actually hard to think of any mechanism which would give rise to
zero resistivity and would *not* imply some sort of a flux quantization.
Zero loss suggests that electrons must travel ballistically around the loop
(no collisions), and uniqueness requirement of their wave functions
then dictates that quantum phase must shift by integer times 2pi around
the loop.
Some ways out would be to find some charge carriers which don't come
associated with a quantum phase, or to find a collision mechanism which could
scramble the quantum phase but conspire in such a way that no net energy
loss takes place. I guess such mechanisms are probably forbidden by some
conservation law or another. Actually, the, conspiring-collisions mechanism
sounds a bit like the Frölich interaction, which *does* lie behind the
BCS superconductivity, but even there the loss of quantum phase of the
individual electrons magically re-appears elsewhere, as the boundary condition
of the order parameter.
This is quite far from the original question, by the way...
Regards
Mikko
