Switch off, Curcuit on
Brendan w.
Jun 11, 2005
23
I was building this project when i came to this problem,
i needed the make a switch that will turn the curcuit on when the switch is off.
I probably could find it somewhere but i don't have alot of time...
          I thougt it would be simple to find it but i can't seem to find it.
If you can give me a simple diagram of something like that i would really appreciate it.
Thank You
tofarley
Mar 30, 2007
I'm looking for something similar as well. I have a circuit that uses a motion sensor. Typically, the output from the motion sensor powers the base of an NPN transistor. For my project, I would like to power the circuit when the motion sensor *stops* registering. Not to say the circuit should run continuously (in which case I would simply substitute a PNP) The circuit should activate once, to operate a solenoid, whenever the motion sensor stops sensing. I'm hoping for an analog solution to this problem.
Any assistance would be greatly appreciated!
audioguru2
Apr 6, 2004
12,022
Brendan,
Just buy the switch.
A double-pole switch has two separate sections.
A double-throw switch has two positions.
Get a double-pole, double-throw switch then one section can turn on something while its other section turns off something.
