Switchable Cathode Bypass Capacitor for a Tube amp
Jim Nomad
Nov 26, 2012
13
Hi All,
I am building a simple tube amp using ECC83, I read that the value of the Cathode Bypass Capacitor can have an influence on gain at different frequencies and headroom. Would it be possible to build in a switch so that I can switch between different capicitors and a a consequence produce fully / partially / un - bypassed effect . If so would attached circuit do the job ?
Many thanks
Jim
  • cathode-bypass-capacitor-selection-circuit.pdf
14,317
That should be possible, although I'm in no position to judge the effect.
I suggest you put the switch on the cathode side of the capacitor.
duke37
Jan 9, 2011
5,364
The 1uF capacitor will give a turnover frequency of about 100Hz, the 2uF capacitor about 50Hz. I think the gain will rise as the frequency rises and be limited to about 10 times the basic amplifier.
If you wish to reduce the gain and improve linearity with a constant gain, then you can put a resistor in series with a large capacitor.
CDRIVE
May 8, 2012
4,960
Good point Duke. This would be the most logical way (SOP) to do this. It applies to BJT's and JFETs as well.
Chris
