Switcher Repair Hints
jrshedden
Hi All,
I still enjoy this forum, even though I have to sift through the spam.
It's a real shame.
I have a Supermicro computer with a 'triple redundant' power supply.
That means 3x250 watt modules in a backplane and rated at 500 watts.
You can loose one module and still be in spec.
I lost a module, had it repaired under warrantee, and lost the the
same module again. It is an Ablecom Model SP 252-TC and I can find
nothing on it, including the card edge connector pinout. It looks very
well made and it I see quality components crammed inside. Supermicro P/
N is PWS-0035(M). Some research indicates it may have been made by
LiteOn.
The module will run for 30 seconds, then shut down for 20, then
repeat. An 'amp clamp' on the input shows about an amp when it's up,
and less than 100 mA when it's down, so I have to figure out why it
decides to give up and retry.
I could really use the edge card pinout of this type of supply and any
hints as to this type of symptom to save me reverse engineering time.
I'm thinking thermal, and if I can coax the supply into operation on
my bench, freeze spray will probably indicate the problem in short
order.
I am aware of proper safety procedures.
Thanks in advance!
Jim S.
Jerry G.
I have not worked on that particular supply. I found that on most of
the supplies that I have serviced, they had caps that failed or became
thermo sensitive.
What I can suggest to get an ESR meter and test all the caps. Heat the
module up with a heat gun so that it is warm when testing the caps.
All the caps that read too high in ESR should be changed.
If the fault is more complicated, the supply will be very difficult to
service without the schematics and a source for the proprietary parts.
In the modern supplies they use a lot of SMD technology with very
specialized IC's, custom made transformers and inductors and devices.
As for myself, I found that the majority of times these supplies are
not worth to service. You can end up spending many hours and a lot of
money on parts. In the end you may have a supply that you cannot have
some specialized parts you need and you spent a lot trying to fix it.
Jerry G.
__
F
Franc Zabkar
Hi All,
It's a real shame.
LiteOn.
order.
Thanks in advance!
Jim S.
All I could find were the ratings of the outputs:
http://www.supermicro.com/support/resources/pws/
The obvious thing to check when you suspect thermal problems is the
fan.
Otherwise, with the unit powered down, can you probe for continuity
between the backplane pins and known voltages on the motherboard (eg
PCI slot) and peripherals?
http://pinouts.ru/Slots/PCI_pinout.shtml
http://pinouts.ru/Slots/IndustrialPCI_pinout.shtml
I've never worked with a redundant, hot swappable PSU, so I don't know
if what I'm asking makes any sense.
- Franc Zabkar
jrshedden
Thanks for the 2 replies. I hope I'm properly posting so you both can
see this. Am I correct that a 'Reply' is to all and a 'Reply to
Author' is in response to a particular post?
Franc:
Thanks for the pinouts. There are 3 backpanes in the server. Once is
the motherboard I/O expansion (PCI-X and PCIe on this one). The second
is the SCSI backplane where up to 7 disk drives plug in. The third is
the power supply backplance (Supermicro calls it the 'power
distributor') where 3 identical 250 watt power supplies slide in from
the back of the machine and connect via edge card connectors. Each
power supply has its own power input and its own fan, so the server
has 3 power cords. When the supply goes down, its fan stops because it
probably runs off it's own 12 volts, but it is going strong when the
supply is up and the exhaust temperature matches the other 2 within 3
or 4 degrees F.
Jerry:
I built the Dick Smith ESR tester, and I will check all the caps when
heated. I'm taking your advice and replacing the supply, but I will
probably hack around the module to see if I get lucky. It will take
some luck or an inordinate amount of time without schematics.
Solution:
ACS Industrial services would fix the module ($250 minimum) and
Supermicro would sell me a refurbished 760 watt triple redundant (3
modules + backplane or power distributor) for $300 or $330 (I forget).
It's ordered and on the way. Too bad the &60 watt modules are not
compatible with the old backplane.
If I figure out the module problem I will repost the result.
Thanks for the help.
Jim
