Tank ckt
audioguru2
Apr 6, 2004
12,022
A tank is an inductor and a capacitor in parallel and they resonate.
At the resonant frequency their impedance is very high and current transfers back and forth between the inductor and the capacitor.
indulis
Nov 21, 2005
488
You neglected to explain about their impedance values at resonance... and what about "Q"??
audioguru2
Apr 6, 2004
12,022
Hi Indulis,
I think Shahzad is a nooby. I answered him with the basics but if he asks for more details then you be his teacher.
indulis
Nov 21, 2005
488
No... that waveform looks like a simple RC integrator.
At resonance it would oscillate at 1/2*pi*(L*C)^.5
shahzad-h
Mar 27, 2006
42
Hi indulis
  my main question is that how it produces sharp wave form
audioguru2
Apr 6, 2004
12,022
Anything that resonates with a high impedance makes a sine-wave. A sine-wave is very smooth without sharp edges. Sharp edges on a wave are caused by harmonic distortion because harmonics are added. A sine-wave doesn't have harmonics, just the fundamental frequency.
indulis
Nov 21, 2005
488
At resonsance, the impedance approches infinity (this of course is impossible... there are always circuit paracitics).
From the WWW...
The solution to the circuit (which is a second order differential equation) is
i(t) = Ae ^+ jωt + Be ^− jωt
Considering the initial conditions, solve for A and B.
Because there is a complex exponential (thats the "j" part), the solution represents a sinusoidal alternating current.
Kevin Weddle
Feb 23, 2004
1,620
When calculating a tank, does the high impdeance differ if Xc=Xl=50 ohms from Xc=Xl=100 ohms?
When you connect the tank at the collector of a transistor, at DC the collector is at the supply voltage. When you apply the signal, does the peak hit the supply voltage, then go down from there with the size of the ouput signal? In other words, at what DC does the signal hover?
audioguru2
Apr 6, 2004
12,022
Hi Kevin,
Welcome back. ;D
The impedance of a tank circuit at resonance is determined by its Q. Usually it is the inductor's resistance that reduces the tank's Q. Therefore an inductor with a lower reactance would have a lower resistance then the tank would have a higher Q and a higher impedance, but with it the bandwidth is reduced.
I haven't looked for many years, but when the DC collector voltage averages at the supply voltage because the resistance of the inductor is very low, then I think the signal voltage at the collector varies above and below the supply voltage.
Kevin Weddle
Feb 23, 2004
1,620
Thanks for leading me in the right direction concerning the first question. I had hoped a larger reactance might mean a higher impedance. Kind of disappointing. I don't like the second answer either. I was hoping it would just pull away from the supply voltage. Oh well.
