I have a Tascam DA-30 that did work fine but now it won't play. It powers on fine and rewinds and fast forwards but when play is pressed, it gets a fast whirring sound and the tape starts fast forwarding (but not like in fast forward mode). The only way to stop it is to press stop. Below is a link to a video showing the issue. You can hear the problem when the unit is first turned on, then I press play and you can see the issue. I then show how FF and REW work fine. I cleaned the heads but no luck. Any ideas? Thanks.
