technics amp
shaggy1978
May 3, 2012
3
i have a technics sua700mk3 amp that keeps blowing the internal fuse with nothing conected no scorch marks on the curcit board any sugestions? ps i carnt spell
14,487
hi there
welcome to the forums :)
specifically which fuse is blowing ? is it the one on the mains power input labelled F1 T2A ? or is it one somewhere else in the unit ?
I found a service manual online so if you can tell me where that fuse is I may be able to help :)
when you say "nothing connected" I assume you mean the speaker lines and inputs ?
shrtrnd
Jan 15, 2010
3,902
I'm not familiar with the model described here, and like davenn said, it matters what
fuse you're talking about (power or speaker fuses).
My comment is I've run across a couple of amplifiers over the years that will blow
fuses if you turn them on without any load.
Check your owners manual, make sure it's ok to power the unit up with no load.
Or that you don't have the power control at a very high setting when you power the amp up.
docb
Feb 11, 2010
131
Is it discrete or an IC for the power amp section?
14,487
the power amp is an IC module
The OP still hasnt returned to answer my questions ;)
shaggy1978
May 3, 2012
3
sua700 mk2
cheers dave and sorry for the delay computer probs) yes its the main fuse f1 1.6amp on the power board . if the unit is on standby its fine but as soon as you turn the amp on flash gone fuse blown . and yes nothing connected means no speakers or inputs or outputs. any help much apreciated. ps were is spell check? when the problem first happened it was connected to all the out puts as it has been for years. i am new to these forums and dont understand some of the terminology used sorry and please bear with me
shaggy1978
May 3, 2012
3
not sure what you mean by this.
14,487
discrete = individual transistors
IC = power module IC ( Intergrated Circuit)
But as I responded a few posts ago its an IC power module rather than discrete devices
docb
Feb 11, 2010
131
Since you have no varaic, I'd start by desoldering the output IC, and see if power comes on without blowing the fuse.
