Tektronix 2235 reduced horizontal sweep
erdrd
Nov 20, 2016
The scope was working great... then I moved.
When turned it on after unpacking I noticed that sweep only showed only in the left side of the display. Could move it a bit towards the right (to the 1st major division to right of center) with the Position adjustment, at which point the waveform got a bit compressed. I could also move it off screen to the left for a couple of major divisions.
I then opened the scope up (I have a scanned service manual) and adjusted the Geometry (R870) to center the waveform. With a 1 kHz sine input at , I get a maximum display width about 1.5 major divisions off the center to each side. I can move the display fine left and right with the Position adjustment.
I then tried adjusting the A GAIN (R740) (based on this https://goo.gl/k5iZZJ ) which allowed for a bit more (maybe 1 or 2 minor divisions) display.
Then I noticed that pressure on the bottom of the board or deforming/twisting the scopes frame will restore the normal width display (now out of calibration thanks to my trimming), so I suspect I have a bad solder joint somewhere (I suspect the high voltage system but I have a great deal of respect for 7kV)
Before I go through a wild goose chase, anyone have an idea what I can narrow it down to?
TIA, Dre
73's de Edd
Aug 21, 2015
3,730
Sir erdrd . . . . .
A good check for connections itermittency is with repeated tappa-tappa-tappa from the plastic handle of a small screwdriver . . . .while you watch the display vewy-vewy carefully.
73s de Edd
elebish
Aug 16, 2013
177
Check the horizontal sweep output transistors and wiring going to the (side) pins on the neck of the crt. These crt's generally have electrostatic type deflection circuits that contain a voltage of about 200 to 300 dc. Be careful not to break these pins or the neck!
vk2ipd
Nov 11, 2009
I have a very similar problem with my 2235. It has a reduced horizontal sweep (not sure if I am right). Actually, I can't see the display at all in normal operation but when I press the "Beam Find" I can see the beam. By keeping the Beam Find button holding and applying a 1 MHz signal from a Sig. Gen, I can see only vertical deflection but no sweep/ trace horizontally. Also, the horizontal screen is reduced in size and does not stretch to the full. What actually is the problem with my CRO and where should I start looking? Is it a Horizontal amplifier or sweep or trigger problem? Thanks in advance.
