sure i will make it like the original nice and small, i made mine in a hurry,audioguru said:I think the parts are too far apart on your PCB which causes high stray capacitance and inductance.
The project has a PCB that is much smaller than yours. Why not make it exactly the same?
exactly, i thought of the same thing and did not worry much about the tinned copper coil,audioguru said:Two coils have their turns tight together and their wire must be enamel insulated. The other coil has its turns spread apart so it doesn't need insulation. Tinned wire is easier to solder but the circuit doesn't need tinned wire.
yeah even i noticed them in the datasheets, i'll reverse the connections and try, but what if it doesnt work again?????audioguru said:The pins layout on European transistors like the BC547 are reversed from American transistors like all the ones shown.
hmmmm, that is very interesting, is there a way i can stabilise the voltage using an LM317, or that wont help?audioguru said:\
Everty phone line has a different voltage so you won't know what RF frequency it transmits on.
That is probably what your problem is.
this means that it cannot be done successfully, not a problem,audioguru said:But the telephone line's voltage might not be high enough for the telephone and this transmitter drawing current plus some overhead voltage for the regulator and series resistor.
if that is the case then i can use a 9V battery to power the transmitter while connected to the phone line,audioguru said:If you are far from the telephone exchange then your off-hook voltage will be low enough to operate a single telephone. If the phone draws a high current and you are far from the exchange then your voltage will be too low to also power the bug transmitter.
