Testing High Voltage Rectifiers
grasshopper
Mar 24, 2013
26
Hi All,
Can you please advise on the correct way to test a
ST TH8S06FP high voltage rectifier.
Many thanks
grasshopper
shrtrnd
Jan 15, 2010
3,902
Did you try to find the manufacturer's data sheet for it?
Typically, the manufacturer has a test circuit for the device at the end of the data sheet.
duke37
Jan 9, 2011
5,364
I looked up the data.
600V, 8A, 1.5V forward, 12ns
What do you want to know, if the diode is blown, then a simple resistance measurement will do.
If you want to know whether it complies with the data then sophitcated equipment will be needed.
RHeTTRoNiCS
Mar 28, 2013
35
Put multimeter in diode mode...check the diode in forward and reverse...In forward should read about 0.5V and in reverse should read higher....otherwise, diode might be faulty....
grasshopper
Mar 24, 2013
26
Data Sheets
Hi All,
I do have the datasheet but there is no test circuit shown. It is 8 pages long and too large to post here.
I have tested the component with a DMM initially in circuit on board and then having removed it off board.
It reads OL (Open Line) in both directions, suggesting a failed component?
Before I condemn the component as failed I would like to be sure that the basic DMM test is valid for this component.
I have seen a you tube clip that involves testing high voltage rectifier diodes using a DC power supply, a series resistor and measuring the voltage in both directions across the component. You tube being what it is, I was keen to confirm and learn the correct test approach.
The component is from an LCD TV power supply project I am working on which is another post on the forum.
Any help is greatly appreciated.
grasshopper
Mar 24, 2013
26
Data Sheet ZIP File
Attached is a ZIP file of the data sheet for the component.
  • datasheet.zip
RHeTTRoNiCS
Mar 28, 2013
35
High potential diode is faulty if dmm on diode mode read OL with both directions...
I haven't watched the video, but it is worth pointing out that some older "stick" rectifiers had a very high forward voltage due to them being composed of many diodes in series.
I would find a current limited high voltage DC source to measure the voltage drop in both directions to determine if there is any diode action.
You could start with something as simple as three or four 9V batteries in series connected to the diode via a 10k resistor.
edit: looking at the datasheet, it's not something like that, so 0L in both directions is very bad.
grasshopper
Mar 24, 2013
26
Latest update
With the DMM in diode test mode the rectifier reads OL in both directions.
Out of curiosity I switched the DMM to measure resistance.
This time it reads OL in one direction and 1.235Meg Ohms in the other direction.
I seem to be getting a lesson here on using the DMM in diode mode verses resistance scales???
What do I need to learn here guys?
That this diode is no more! It has ceased to be! 'E's expired and gone to meet 'is maker! 'E's a stiff! Bereft of life, 'e rests in peace! If you hadn't nailed 'im to the bench 'e'd be pushing up the daisies! 'Is semiconductor processes are now 'istory! 'E's off the twig! 'E's kicked the bucket, 'e's shuffled off 'is mortal coil, run down the curtain and joined the bleedin' choir invisible!! THIS IS AN EX-DIODE!!
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
If the rated forward voltage is 1.5V as you say, it may read open circuit in both directions on your multimeter, depending on how much voltage the meter applies. A better test would be a 9V battery, an LED and a series resistor e.g. 3k3. Connect like this:
negative_probe ---------- -_9V_battery_+ ---------- anode_LED_cathode ---- resistor ----- positive_probe
With the positive probe to the anode and the negative probe to the cathode, the LED should light. The other way round, it shouldn't.
grasshopper
Mar 24, 2013
26
ODE to the DIe=ODE
Resistance is no longer low,
The current can no longer flow,
The power on its just no go.
The poor component has to go
It simply cannot switch the flow,
A new part comes from far away,
A fresh Diode to save the day,
I hope my TV works some day,
The forum;s cool it shows the way,
We live to learn and work then play,
My old Die=ode has had its day,
Gone to scrap I learnt today,
Now I'm simply blown away.........
I could have sworn that 1.5V was not too much to read on the diode test range.
I just tested with a red LED and only one of three meters I pulled out could show the forward voltage on the diode test mode.
Try what Kris suggested -- a variant of what I suggested when I thought you might have an old stick rectifier.
duke37
Jan 9, 2011
5,364
The 1.5V drop will be with 8A. I expect it will be a single diode with a drop of 0.7V at low current.
My normal analog meter uses 3V for the resistor ranges, which would test a diode with 1.5V drop. It has the disadvantage that it will blow a small transistor on its lowest range.
sheldonstv
Jul 17, 2007
68
heres a simple diode tester i use with mw high voltage diodes....but a simple check on your dvm on diode test should do as long as the meter provides enough forward voltage for the device under test....
That was my first thought on reading the datasheet.
However, on a closer look at the V vs I curve for 25C, I was less certain.
