Do you think a 6 mm square head isn't going to work ok with a 6.35 mm
square socket hole? I don't think the 0.35 mm difference (if it is that
much) will even affect the detent. Am I wrong about this? I expect a
square connection would be much more forgiving of size mismatch than a
12 point socket on a hex nut.
The difference (between socket and driver) is less than 0.2mm on a
1/2" socket. A 12mm driver would more than quadruple the slop. Might
not be healthy if you're trying to free a frozen bolt.
Sounds like a good reason to just give in and spend the extra few bucks
to get the metric stuff. I wonder how the rest of the world manages?
It much be a PITA knowing they are paying too much for their tools.
It's not just spending the extra bucks once, I'm quite willing to do
that (and have with some machine tools), it's the continuing supply of
a wide range of metric sizes of cutters, taps, reamers and such like
that causes hassles. I've actually gone backwards (more inch stuff)-
with calipers and micrometers and DROs that switch, it's not so bad.
I'm certainly not going to try to find boutique suppliers of A4 paper
and fittings for whatever Europeans use instead of NPT threads. It's
not like the inch numbers mean much anyway.. 1/4-NPT is 0.54"
diameter, for example. At least the TPI numbers mean something. The
taper is 3/4" per foot. ;-) And chucks etc. use JT tapers and Morse
tapers and R8 tapers, which are inch. It's a dog's breakfast. 20 gauge
stainless sheet is thicker than steel, which is thicker than aluminum.
I'm sure the metric tools are cheaper and more available than inch are
outside North America, but I'm not there. Somtimes I'll bite the
bullet and pay 100x the going price for metric fasteners when
something is going to be assembled offshore. said:
There are plenty of times when I get tired of trying to do the math on
feet, inches and binary fractions of an inch. Where do I mark cuts on a
board 3 ft, 3 3/8 inches long to space out three notches 1 5/16 wide so
the un-notched areas are all the same width? With all round metric
values I can do that in my head. 33 1/3 mm notches and 225 mm
un-notched areas.
I remember conversion cards to go between decimal and fractional inches.
I've never seen anything like that for metric. Living in the metric
world is the best way to go, living in both worlds is the worst way to go.
It's nice to have the imperial units sometimes.. for some
applications, BTU/hr*ft*°F might be just the ticket. But usually I
find the metric makes life easier. Living in both worlds gives a bit
more variety in things at times too. Letter size drills, drill wire
gauge sizes, metric drills, fraction inch drills- there's bound to be
something that makes a hole I can live with.
Best regards,
Spehro Pefhany
