Syd Rumpo
- Jan 1, 1970
- 0
Oh, I forgot the best one: we are still donating blood by the pint.
Strangely, in the UK we give a US pint of blood instead of the larger
imperial measure.
Cheers
Yeah, part of the mantra here after donation is not to drink that day. IThat's so you could go for a beer afterwards and come out ahead.
Cheers
Phil Hobbs
Maybe I should get this vanity plate: *PHUT*josephkk said:On Sat, 16 Feb 2013 08:58:41 -0700, Jim Thompson
rickman wrote:
[snip]
Heck, I
worked at a company just a few years ago that made push to talk radios
for the US military. I was surprised that the mechanical engineers were
still using inches and converting all the metric stuff rather than doing
it all in metric!
Surprised? Some of my work is in aerospace. There it's all inches,
pounds, PSI, slugs, knots, feet and so on. To some extent that is even
so in the medical device industry. The topper:
[snip]
You forgot "Jerk"... the derivative of acceleration... used in
elevator specifications >:-}
...Jim Thompson
That reminds me of the day i saw dA-dt on a licence plate.![]()
No asterisks. Maybe you could get "PHUTTER". ;-)
Sylvia said:Do those sizes take into account the inevitable dimensional changes that
result from any mention of catheters?
The speed of light is about 1.8E12 furlongs per fortnight.
I still have old stuff that SAE wrenches are good for, but everything
on cars seems to be metric these days with few exceptions. Some
dimensions in that Chevy are obviously hard metric (the bore and
stroke size of the smaller engine is 96/92mm). The larger engine is
mixed.. metric stroke and 4" bore.
It's a hassle to design solely in mm when tool and material sources
are largely from the US or made for US customers. More digits to enter
when machining* because Imperial tools are more available and cheaper,
less availability and sometimes higher cost of things like reamers,
etc. I don't mind 6-32 screws, for example, provided they make them
for me with Phillips heads (or Robertson or Torx). Flat blade
fasteners- ugh. The coarser thread compared to metric standard zips in
faster with the electric screwdriver.
Do any Euro socket sets use mm drives? All my tools use 1/4, 3/8, and
1/2" drives. It would be a total PITA if there were 6mm/10mm/12mm
drive sets (assuming they exist) in the same work area.
* For example, the standard edge finder I can buy easily/cheaply has a
0.2" diameter, so the offset is 0.1" from the edge of the work. (also
0.5" diamter). I can get metric end mills, but 0.25" diameter is
cheaper than 6mm. I can set the DRO to metric, but I'll have to offset
it by 2.54mm to get the edge, and 3.175mm to offset the tool radius.
vs. 0.1" and 0.125".
You're an idiot... quite old... Probably all your life.
More likely a 14mm.
So, you are too stupid to know (obviously)that some of the values match
up closely enough to substitute for each other.
US vehicles are metric. That includes General Motors Corporation, you
fucking idiot.
"I'm not an asshole, but I *play* one on the Internet." - Lord Valve
It is not very far from pounds and guineas (20 and 21 shillings).
On 17/02/2013 19:40, cameo wrote:
Even simpler is binary, like 1 inch, 1/2", 1/4" 1/8" etc.
And of course standard PCBs are both 1/16" and 1.6mm - spooky.
Miles are just hexadecimal kilometres. 80km is 50miles (0x50 = 80) and
30mph is 48kph (0x30 = 48). OK this may not always work...
Cheers
Part of the reason is that one nautical mile is (about) 2000 yards,
making lots of mental calculations much easier. It's formally defined
as 1852 meters but that's kind of unwieldy for most people trying to
do math in their head.
Dropped at the same time from the same height, which would hit the
surface of the moon first?
With one dropped on the near side center, and the other dropped on the
far side center?
The only non-metric tool I still use consistently is a 7/16" wrench for
TV cable end-connectors. I guess I could also use an 11 mm metric wrench
which is about the same size. So I'm not even sure if those connector
specs are metric or not.
Tim said:Metric is kind of nice because you can "make your own" when it comes to
magic sizes and stuff. Sometimes you want, say, a plate that's 1/4 or
3/8" thick, but it just doesn't look quite right -- visually appealing.
Instead, you could specify 5, 7.5, 10, etc. mm thickness, or other odd
values, assuming it's in stock of course -- and potentially get more
elegant proportions and whatnot.
I looked at 3 datasheets on digikey, they all say the hex is 11mm.
the thread's not metric though, 3/8-32UNEF-2B
Yup. Most are dimensioned in hard metric (11mm across the flats).
Pomona's data sheet shows 7/16, which they dimension to 0.43 in
decimal inches (rather than 0.4375), and convert to metric at 10.92
(7/16" is exactly 11.1125mm). Sigh.
http://www.pomonaelectronics.com/pdf/d6709_001.pdf
FWIW, the nominal dimension given on hex nuts seems to be the maximum,
with tolerance allowed on the less-material side. I'm sure there's
some DIN standard, as there is a standard for Imperial dimensioned
external flats.
Even with a Philips head screw, one should use the correct size, and
make sure the insertion force is applied correctly before torqueing in
either direction.
Even more fun are Allen keys and hex keys. Those generally require
the utilization of the exact correct and proper tool to properly torque
the fastener and also not ever damage it.
wheras the older Phillips was deliberately designed to
cam out.
I think I discussed this recently in one of the groups. I remember
distinctly (or as well as I am capable of remembering) that in the 70's
we agreed to move to metric coordinated with Canada. It was a
multi-step program with information and education being the first two
steps. We even required the US auto makers to add metric to the
speedometers. But when it came to actually changing something (I think
speed limits was the first thing to change) we told Canada to go on
without us and we'd catch up... which we *never* did.
I expect there was too much push back from the average Joe. Heck, I
it all in metric!
Converting is inevitable, but perhaps not until it starts to make an
economic impact. By then China will be running things and we will just
be the tail on the dog.
