THE WORLD NEEDS COLD FUSION.
We can make energy out of matter, and matter out of energy. With cold
fusion, we will unlock the power of the atom, and the world will have
infinite energy and be able to create matter out of energy and thus
infinite wealth.
Cold fusion is for real. Just like the light bulb it may take many
attempts to get it right.
Thomas Edison failed more than 1,000 times when trying to create the
light bulb. When asked about it, Edison allegedly said, "I have not
failed 1,000 times. I have successfully discovered 1,000 ways to NOT
make a light bulb." He then succeeded, and now the world has light.
http://en.wikipedia.org/wiki/Cold_fusion
From Wired Magazine "What If Cold Fusion Is Real?"
http://www.wired.com/wired/archive/6.11/coldfusion_pr.html
"That's what makes cold fusion so nonreproducible," says Storms. "You
have to load the palladium with very high concentrations [of
deuterium], and many samples simply won't tolerate it."
"Heat has practical applications," concedes McKubre, "but what am I
supposed to do with the ability to turn expensive elements into cheap
ones?"
This, finally, is his explanation for many negative results. There's
still a snag, though. Just because he knows how to select good
palladium, doesn't mean he knows how to make it. "Pons and Fleischmann
used to test samples from a supplier, Johnson Matthey, and over the
years they figured out how to create palladium that worked most of the
time. But Johnson Matthey signed a nondisclosure agreement with
Technova, the Toyota-supported group that financed the research in
France. The Japanese thought cold fusion would be hugely successful,
and therefore everyone would want this certain type of palladium, and
they'd clean up."
Of course, it never happened. Technova abandoned cold fusion. But
according to Storms the nondisclosure agreement still exists, and
Johnson Matthey is still bound by it. (A spokesperson at Johnson
Matthey would not confirm that an agreement exists.)
"Someone should buy it from Technova," I suggest.
Storms laughs. "Why should they? It's worthless! You can't make any
money from cold fusion - at least, not using the Pons-Fleischmann
method."
And so, at this point, Storms is stymied. He shows me a paper he has
written, with a grim cover letter: "Ironically, it is now possible to
know why we failed but it is too late to follow a more successful
path ... Without access to widely circulated journals, this negative
attitude within the scientific community obviously cannot be changed.
Even overwhelming proof, as demanded by many scientists in the past,
can have no effect because no mechanism exists for it to be
communicated to the scientific professions."
H
==Harley==
The world may need it, but it's not gonna get it. Fusion is always 10 to 15
years away.
Harley
