Thermal Hysterisis
Linear
Has anybody on this newsgroup got any information on thermal hysterisis
regarding input offset voltage on op-amps. How big is the effect? How to
minimize? Etc.
R.Legg
minimize? Etc.
This is caused by thermal gradients occuring across the IC substrate
as power dissipation varies. The hysterisis effect is time-related,
rather than static, as the temperature gradient lags the dissipation
change.
The cure is in layout of the IC - differential inputs will have a
symetrical physical relationship with and exposure to the major load
and line dependant dissipators. As a result the inputs see the same
temperatures under varying gradients, as the dissipation varies.
There are other thermal effects external to the IC that also have to
be watched.
RL
R.Legg
minimize? Etc.
The bit about hysterisis and time.
If the input signal persists long enough (in the poorly laid-out IC)
to establish a die temperature change in an open loop or comparator
stage, the threshold will appear to have drifted when the signal
reverses, and vice-versa, as the temperature gradient across the input
transistors has changed.
For audio AC signals, a change in output amplitude (and internal power
dissipation) results in a gradual DC offset change that is inevitably
reversable, with no real static hysterisis.
RL
