thermal noise
Allan Adler
How does one measure thermal noise in a resistor?
Ignorantly,
Allan Adler
[email protected]
* Disclaimer: I am a guest and *not* a member of the MIT Artificial *
* Intelligence Lab. My actions and comments do not reflect *
* in any way on MIT. Moreover, I am nowhere near the Boston *
* metropolitan area. *
Jerry G.
This is a complex answer. Noise must be compared to something, such as a
standard. The noise in a component such as a resistor would be dependent on
factors such as the temperature of the device, the current through the
device, the applied voltage, the frequency of the voltage, waveform or
structure of the applied voltage, and the humidity if the resistor is of a
high enough value. These are only the simple attributes that I can think
about at this time.
As for noise measurements, they are usually compared or scaled to some type
of reference. You can measure the noise in simple volts, but this would be
meaningless by way of definition unless you have a standard to compare it
to. When publishing the noise factor, all the conditions of the test must
also be specified.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
Ignorantly,
Allan Adler
[email protected]
Sir Charles W. Shults III
Simple comparative means are to measure noise at a given temperature, then
change the temperature and try again. Since the thermal noise power in Hertz is
equal throughout the frequency spectrum, you only need to worry about the values
of k and T where k is Boltzmann's constant, and T is the temperature of the
conductor in Kelvins.
Cheers!
Chip Shults
My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
U
Uwe Bonnes
: How does one measure thermal noise in a resistor?
: Ignorantly,
Connect to an RMS voltmeter at much lower temperature
U
Uwe Bonnes
: Ignorantly,
Connect to an RMS voltmeter with the voltmeter at much lower temperature and
the resistor at nominal temperature.
Bye
CWatters
This page has notes on how to do the experiment (scroll down to the
subheading "Experiment" on page 3)
http://www.physics.utoronto.ca/undergraduate/PHY_225H_280F-281S/experiments/
thermal-noise/Thermal-Noise.pdf
(Long URL may wrap and need repairing)
Colin
Ignorantly,
Allan Adler
[email protected]
