[email protected]
- Jan 1, 1970
- 0
Hey everyone,
I'm very much so a newbie at electronics, but figured I'd try and tacklea problem for my scout group: making a pinewood car timer.
I found this schematic online that uses optical transmitters:
http://www.hmpg.net/pinewood/GenericPinewoodTimerSchematic.pdf
I have hooked everything up as seen in the schematic to the best of my ability... I have hooked up the parallel port grounds (Pins 18-25) also to thenegative row at the bottom of my breadboard, so all the grounds are on thesame line (I couldn't figure out how else to do that).
Here's my problem: Using parmon to monitor the parallel port, when I hit any of the sensors (say the start gate for example), it changes the status on all the pins that are hooked up.
Example:
Pins 10,11,12,13, and 15 all read "1". I trigger the start gate switch (hooked up to pin 15). Now ALL of my pins (10,11,12,13, and 15) all toggle over to "0". Similar thing happens if I hit just ONE photoelectric diode with a flashlight, ALL trip to 0, not just the one pin that that diode is hooked to.
I've written my matlab code to poll everything and run the race, but since I can't differentiate which sensor is getting twigged, I can't determine which sensor came across first...
Any help/suggestions would be fantastic.
Thanks in advance,
Andrew
Example:
Thanks in advance,
Andrew
