Timer. What's wrong
Karl Gega
May 23, 2005
18
I have projected this timer and built it.
But the output stays always High, i don't know what's wrong with it?
The cap is 2200uF and the resistor is 10k. I have also tried with a 100uF cap but still no change.
Any help?
David Bridgen
May 22, 2005
12
Pin 2 needs to be "pulled up", so connect a resistor from it to the positive supply.
David Bridgen
May 22, 2005
12
Hmmm .....
The switch on the trigger pin is a momentary action one?
The circuit looks fine otherwise (with a pull up on pin 2).
Karl Gega
May 23, 2005
18
Yes  the switch is a momentary action one.
It is possible that the IC has gone bad because in the beggining i changed  the power
wires by mistake (connected ground to Vcc snd Vcc to ground ) and IC heat up so much that it couldn't be touched with hand (it might have remaind in that state for two minutes).
Should i replace it? Or it is ok.
Thank you for your time.
audioguru2
Apr 6, 2004
12,026
Hi Karl,
With the diode across the relay coil backwards, the 555 IC will burn again. I mentioned other necessary changes in your other topic. ;D
audioguru2
Apr 6, 2004
12,026
The diode across the relay coil (in parallel) is still backwards.
