daestrom
- Jan 1, 1970
- 0
Pop said:Basically, Double insulated is a little misleading, but in UL/CSA
parlance, it means that the internal wiring is such that it would take TWO
faults to occur, either of which would stop the product from working,
before anything could become electrically dangerous to the user. Usage
conditions are also taken into account.
Among other things it also means that there cannot be any exposed metal
on the product. ALL exposed metal must be grounded, which become a
non-essential in double insulated products.
It also means it doesn't need a third "prong", and the blades do not have
to be polarized on the two-blade plug, and it does not need a 3-hole
outlet.
Not entirely true. The classic example is a double-insulated inexpensive
power drill. The chuck that holds the bit is metal, and is not grounded.
The tool does not have a third prong grounding conductor. But it meets the
definition of double-insulated because the chuck is insulated from the motor
by nylon gear-drive. And the windings on the motor are, of course,
insulated from the motor frame. So it would take two faults, just as you
said. It has no third prong, also as you said. But the exposed metal parts
are *not* necessarily grounded.
daestrom
