tiny 12v fan for my miniature models to exhaust humidifier vapor/misthi
Crafts4Me
Feb 10, 2022
168
my models are all 12v and on a 1:12 scale
i have a retile humidifier from the back to add "steam": from my boiling pots
i need some type of mini fan to ehaust the "steam" through the "chimney"
any suggestions
it needs to be really small and 12v
14,311
What is "really small"?
PC fans operate on 12 V, but most likely are still way to big for you, are they?
Here's a really small fan, operating on 3 V (works probably on 3.3 V, too, whcih I take it you have somewhere in your miniature)
A tad bigger are these. Works on 5 V. I'm sure you have 5 V from your USB power available.
This one is 12 V.
I don't think you'll find smaller ones - at least not at a reasonable price.
Why do you need a "really small" fan? Couldn't you use any fan, a flexible tube and an adapter (possibly 3D printed) to direct the airstream to where it is needed? This way you can mount the fan in a convenient location somewhere else, somewhere where size doesn't matter.
You could also power multiple tubes form a single fan.
Crafts4Me
Feb 10, 2022
168
hi
i need a 2-3 " fan mounted in my house thats about 10"
the vapor is directed to appear coming out of the pot
however it pools and makes everything wet
i want to add a fan to my chimney to pull the vapor up
is that possible?
bertus
3,874
2-3 " is about 50 to 75 mm.
A lot of fans have a size of 40 or 60 mm.
Bertus
Crafts4Me
Feb 10, 2022
168
thanks
i ordered a 3" waterproof fan nd will mount inside the chimney to blow out
lets see if it works as i imagine
Crafts4Me
Feb 10, 2022
168
the smaler ons are not waterpproof this si the smalles waterproof one i found in areasonable price as a test
lets see
i will report back
house is 10" tall 8" widex 7" deep
thats very small
bertus
3,874
Your link does not work.
It requires a login.
Bertus
Martaine2005
May 12, 2015
5,317
Have you wired the fan correctly?
It may be pulling air rather than pushing?
Crafts4Me
Feb 10, 2022
168
there is only 1 way to wire otherwise it wont work there is a + and - thats it
in my application mini rooftop i have the fan in backwards menaing outside it blows cool
i thought it would exhaust the vapor from inside and it does not
Martaine2005
May 12, 2015
5,317
Perhaps it’s spinning too fast.
Slow it down with a lower voltage source. See if that works.
Martaine2005
May 12, 2015
5,317
Forget that!
I think you need a much lower RPM.
Perhaps 200-500 RPM. A motor with a gearbox would be ideal.
Crafts4Me
Feb 10, 2022
168
all the fans are much too large
i need this size
the speed adjustor makes it much slower
i need to refill and test the vaporizer again
i will report tomorrow
ivak245
Jun 11, 2021
144
What voltage is marked on the fan and what voltage are you using? The ad mentions 5-12v, but they are usually a fixed input voltage.
