mv said:
I bought a tiny FM radio (made in China!) that has a chip in it
The Chip looks like SDC 304M (Cant make out exactly) and has digits
088
The rest of the radio contains the amp, coils and capacitors.
Now, on to my problem - The radio has "Reset" and "Scan", the radio
was probably manufactured for use in the US so the FM Frequency
increments are different from those used here in India. This means bad
reception. How can I fix this? Lots of people will be very pleased if
they could get better sound from these nifty devices.
Thanks in advance.
mv
When I opened one up (they are down to 99 cents here in Canada) and
after doing some searches, and a bit of tracing, it turned out to
be a Phillip's IC, the TDA7088. I thought it might be a surface
mount TDA7000, and of course that did not match the number of pins on
the IC, but Phillips listed some similar ICs, and one matched in
pin numbers, and when I traced the circuit it was a match.
Below is something I posted when someone asked about this IC before.
I haven't read the datasheet in a while, or maybe not carefully,
but it scans with an analog voltage, with one of the buttons
starting the ramp, and the other button resetting it to start.
There's circuitry in the IC for detecting when the radio is tuned
properly to a station, which then halts the ramp.
I assumed the ramp was not stepped, for the simple reason that
the varicap used to tune the thing would not be linear, so a given
step at one end of the dial would not move the radio to the next channel
at the upper end of the dial.
Given that assumption, and you can read the datasheet to see if I'm
wrong, I would think the radio would work no matter how a given
country's FM stations are spaced.
Now, if the question is actually that the FM band in India is
different from that in North America (88 to 108MHz), then it's
a matter of changing the coil (or maybe just squeezing or spreading
it if the difference is little) so it does cover the proper frequency
range.
Michael
I bought one of those recently, when they were on sale for $1.99 at
Pharmaprix (which is Shopper's Drug Mart in the rest of Canada).
I was simply curious about what was inside, and the price became
low enough that I didn't mind spending the money.
I had problems reading the IC at first. So I started out tracing
the circuit. At first, I thought/hoped it was the TDA7000, but
the pin count was wrong. I looked up that IC at the Phillips'
site (it was easier than trying to find where I'd stashed the
paper datasheet), and they made mention of similar ICs, including
two that had that tuning scheme. I went through them, and
the match was the TDA7088. Looking more carefully at the IC,
the "7088" was now visible, though it looked like it was a knockoff
or a cheap second source, rather than an IC that came from Phillips.
I'd say this is the same IC, since your "1033" could be a misread
of "7088". Check the datasheet at
http://www.semiconductors.philips.com/pip/TDA7088.html
Likely by comparing the pinout from it with the actual circuit, you
will find a match.
I was going to post something about my findings, because they are a curiosity.
But I'm not sure where my notes are, or even where I put the circuit board.
The IC uses the same scheme as the TDA7000, ie a conversion to an IF
of about 70KHz, where an active filter can be used for selectivity.
And one of those Frequency Lock Loops which reduces the apparent deviation.
Then they throw in the circuitry for the tuning scheme.
Having once seen someone suggest using the TDA7000 as a direct conversion
receiver (when they were readily available at Radio Shack), they claimed
the mixer was double balanced, I couldn't help but think maybe these
radios would be a cheap local source for a mixer. Leave the IC on
the board, and just strip the unneeded parts of, wiring to the board
rather than wiring to that smd IC. I assume the big problem would
be that since the 7088 can't handle more than about 3V on the supply
line, it will be even worse for signal handling than the NE602 is said
to be. (And I am simply assuming it's a double balanced mixer.) But
for a couple of dollars, there are times when someone might need
a mixer that these radios can supply cheap and locally.
Michael
