Toshiba 42H82 16:9 RPTV Problem
Larry J.
Set is about 18 months old. Lately, it powers on with wavy vertical
lines in the picture. All sources, cable connections as well as VCR
and DVD inputs.
See: http://members.cox.net/ljvideo/images/wiggles-1.jpg
It starts off looking worse than the above image, and after 5 minutes
or so becomes normal, but the time between powering up and looking
normal seems to be getting longer, and the first images are getting
worse.
I've also noticed that the OSM is not affected by it, so it must not
be anything affecting tha actual CRT scanning, but in the demod, or
somewhere ahead of scanning. The OSM icons and box are perfect.
See: http://members.cox.net/ljvideo/images/wiggles-2.jpg
Where to look for this problem..? Thanks in advance.
Jeff Rigby
and DVD inputs.
worse.
I've gotten two sets that have a problem on the hyper board. Bad cap
leading to loss of sync for the hyper board. After warmup it's better.
Problem starts about two years after mfg. Hyper board is expensive but
haven't found bad cap ($2.00) part since it's impossible to service the
board in the set. Would have to mfg cables to allow work on the board. At
this time since only two have failed it's not worth the cost.
Larry J.
[posted and mailed]
Waiving the right to remain silent, "Jeff Rigby"
Bad cap leading to loss of sync for the hyper board. After
warmup it's better. Problem starts about two years after mfg.
Hyper board is expensive but haven't found bad cap ($2.00) part
since it's impossible to service the board in the set. Would
have to mfg cables to allow work on the board. At this time
Thanks Jeff.
Where to find replacement hyper board, and what's the cost..?
