I would like to create an integrated circuit with the IC TP4056-42 but without the battery temperature sensor. The datasheet speaks that when we do not use temperature sensor we must ground the pin 1 TEMP. In some circuits on the internet the TEMP pin has a resistor connected to the VCC. But the datasheet does not say anything about it, I wonder if the circuit below is correct.
