Track another Voltage rail with fixed 5V drop @500mA question
The Hemulen
I need a Voltage rail to track another rail with a fixed 5V drop between the
two. ie if main rail is at 16V output at 11V, main rail drops to 15V output
at 10V etc. Need to pull up to 500mA from this tracking output.
An obvious way would be a series power NPN transistor with 5V6 zener between
collector and base and resistor from here to ground but I'd also like the
tracked output to have some current protection in case the output gets
shorted.
Is there a sneaky way to do this with standard 3 pin fixed or adjustable
regulators that would provide both the fixed drop between the two and short
protection?
George Herold
shorted.
protection?
You could hang a negative three pin regulator 'upside down' off the
top rail, but that will only sink current. (I think)
George H.
Something cheap, the 6.25 could be 6.2V zener or precision shunt IC:
Please view in a fixed-width font such as Courier.
.. MAIN RAIL >--+-------------------+---------> Vmain
.. | ^ 6.25V
.. | 317 - ref
.. +--|I O|----------|-----+---> Vmain-5 V
.. | | A | | |
.. === -------------+ === C
.. | [R] |
between the two. [...] I'd also like the tracked output to have some
current protection in case the output gets shorted.
Main Rail o---+---------------------------------o Main Rail
+--->|--->|--->|--->|--->|---~~---o Tracking Rail
D1 D2 D3 D4 D5 F1
Ground o-------------------------------------o Ground
D1-D5: 1N4001
F1: about 1 A; fast or slow blow to taste
F1 is the expensive part. :)
Matt Roberds
D1 D2 D3 D4 D5 F1
D1-D5: 1N4001
Ooooooh! That is SO accurate!
It meets all the stated requirements of the original poster. If there
are additional requirements, then the above design may not be
appropriate.
For lower noise:
Main Rail o---+-------------------------------------o Main Rail
+--->|--->|--->|--->|--->|---~~---+---o Tracking Rail
+ | D1 D2 D3 D4 D5 F1 + |
C1 === === C2
Ground o---+---------------------------------+--o Ground
D1-D5: 1N4001
C1-C2: 100 uF. 25 V or more depending on main rail voltage
For better accuracy:
Main Rail o---+-----------------------+----------------o Main Rail
| ____ | | |
+-----+---| U1 |---+-----+ / R5 / \ M1
| + | |____| + | | \<-+======( )
| C1 === | === C2 | / | /\_/
+-----+ | +------+ +----------------o Tracking Rail
\ R1| | \ R3 | |
/ | ____|_____ / | |
| | | Vcc | | | |
+------|Ain1 Ain2|-----+ | |
| | | Dout1|-+ | | |
/ | | U2 | | / | |
\ R2| |___Gnd____| | \ R4 | |
Ground o---+---+-------+-----------+-----------+----o Ground
C1: 100 uF. 25 V or more depending on main rail voltage
C2: 10 uF, 6.3 V
R1, R3: 9k
R2, R4: 1k
R5: 100 ohms, 3 W, wirewound pot
U1: 7805
U2: PIC, AVR or similar (with at least 2 analog in, 1 digital out,
internal clock, internal ADC reference, 5 V supply)
M1: Model airplane type servo motor
Note: === is the mechanical linkage of R5 and M1
Matt Roberds
Jamie
shorted.
protection?
MAIN buss 5..20 Volts
| | |10
z |
4.8V A |
+----+| 5 volt drop
100k | | | |
'-' | |30 output LOAD
GND GND
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
Just an idea..
This is simple and if you are not looking for supper precision
this should do.
You can use a post regulator or something like it ofcourse and
lift the common leg with a zener.
I guess it all depends on real-estate and your needs.
Jamie
Tim Williams
John Larkin said:
Pffbt! And this from the guy who approves of hFE bias in production?
Come on, it's even got damping for those pesky emitter follower mode
oscillations! ;-)
Tim
between the two.  [...]  I'd also like the tracked output to havesome
                 D1   D2   D3   D4   D5   F1
D1-D5: 1N4001
appropriate.
For lower noise:
          C1 ===                               === C2
D1-D5: 1N4001
              |    ____          |    |           |
        |   + |   |____| + |     |    \<-+======(   )
        | C1 ===    |     === C2 |    /  |      /\_/
              \ R1|       |           \ R3      | |
              |   |  |   Vcc    |     |         | |
              +------|Ain1  Ain2|-----+         ||
              |   |  |     Dout1|-+   |         | |
              /   |  | U2       | |   /        | |
              \ R2|  |___Gnd____| |   \ R4      ||
____/ | | / / /___________________/ | | / / /_____
___| |/____________________| |/_____/ |
Main rail Tracking rail | /
____________________________________________________|/
Ground
N
Nico Coesel
shorted.
protection?
A TCA0372 (high power, thermal and short circuit protected opamp), a
shunt regulator and some resistors.
N
Nico Coesel
D1 D2 D3 D4 D5 F1
D1-D5: 1N4001
It doesn't. Look at the datasheet of the 1N4001 and especially the
graph forward current versus forward voltage. And then look at what
the temperature does to the forward voltage.
Spehro Pefhany
What can you expect for 1.2 cents?
1.2 cents? You buying them one at a time at Starbucks?
Best regards,
Spehro Pefhany
LM1117 seems bulletproof in situations like this, where the ADJ pin
could get driven strangely in current-limit situations.
I like to drive LM1117 ADJ pins from opamps, too, to make them into
self-protecting power boosters.
Since there's no ac-ripple to speak of as the input is also regulated, a simple current limiting resistor in series with ADJ should be enough. Since on the modern parts Iadj doesn't budge by 0.2uA typically across all combinations of input voltage and loading varied from min to max.
.. | ^ 6.25V
.. | 317 - ref
.. | | A | | |
.. === '----[1K]-----+ === C
.. | [R] |
The 317 doesn't enough internal resistance to protect itself against excessive current from Adj to Out with Out shorted in this application, so the 1K in series with Adj is required.
The 6.25V reference is best done with a 431 type precision shunt reference IC:
.. | ^ 6.25V
.. | 317 - ref
.. | | A | | |
.. |0.1u | |
.. | [R] |
Nico Coesel said:
some current protection in case the output gets shorted.
D1 D2 D3 D4 D5 F1
D1-D5: 1N4001
It doesn't.
Key word: stated.
Quick version: I know the voltage drop from the main rail to the
tracking rail is going to vary. The original poster didn't say how much
variance was acceptable.
Long version:
Look at the datasheet of the 1N4001 and especially the graph forward
I actually did look at one data sheet (Diodes Inc) before I posted the
first time, because I had one memory of the nominal forward voltage
being 1.0 V and another of the nominal forward voltage being 0.6 V.
That data sheet quotes a maximum forward voltage of 1.0 V at 1.0 A
forward current, 25 C ambient, single phase, half wave, 60 Hz,
resistive or inductive load. (Yes, this application does not meet
those conditions.) So I went ahead with 5 of them in series.
That data sheet also has a graph that shows forward voltages of about
0.7 to 0.9 V over currents from 0.01 to 1.0 A at a _junction_
temperature of 25 C, but this graph also has the test conditions of
"pulse width 300 us, 2% duty cycle". I'm sure there is a reason for
this test condition, but I don't know what the reason is, so it seems
a little weird to me. The application that the original poster asked
about is probably much closer to continuous than pulsed.
I just looked at some other data sheets. Vishay's has a similar If vs
Vf chart, with about the same curve, except their test condition is a
1% duty cycle. Fairchild has a similar chart and curve and uses the
2% duty cycle. ON has kind of a different chart; it doesn't have the
pulsed test conditions, and has curves for three different Tc (case?).
For 25 C, Vf varies from about 0.79 to 0.91 V over If 0.1 to 1 A.
And then look at what the temperature does to the forward voltage.
The Diodes Inc, Vishay, and Fairchild data sheets don't have any
temperature vs forward voltage data. The ON one sort of does, in the
three curves on the same graph mentioned above. At a constant If of
0.5 A, Vf varies from about 0.72 to 0.86 V as Tc (case?) varies from
150 C to 25 C.
So yeah, Vf will vary over If and temperature. The original post did
state a current of "up to" 0.5 A, which implies that it could be less,
so If will probably be changing. The original post did not state a
temperature requirement; I realize the diodes will heat up some from the
power dissipated in them, so temperature will probably be changing.
This means that in this circuit, Vf will change, so the total voltage
drop over D1-D5 will change, roughly in the range of 3.5 to 4.5 V.
There will be a small additional voltage drop from the fuse (Bussmann
says an AGC-1/2 is 0.59 V typical at rated current), so the total
voltage drop from the main rail to the tracking rail will vary over
the range of roughly 4.1 to 5.1 V.
The original post did not state a tolerance on the 'fixed 5 V drop'
requirement. The claim could be made that "4.1 to 5.1 V doesn't meet
the 'fixed 5 V drop' requirement", but that would mean that an
alternative solution that provides a 4.9999 to 5.0001 V voltage drop
also doesn't meet the 'fixed 5 V drop' requirement.
The fanciest DMM I can find in a little bit of Googling is an 8.5-
digit one (Agilent 3458A), and its resolution on the 10 V range is
100 nV. So, I guess if there is a solution that provides better than
4.9999999 to 5.0000001 V voltage drop, it would be hard to prove that
it didn't meet the requirement.
Data sheets referred to:
Diodes Inc http://www.diodes.com/datasheets/ds28002.pdf
Vishay http://www.vishay.com/docs/88503/1n4001.pdf
Fairchild http://www.fairchildsemi.com/ds/1N/1N4001.pdf
ON http://www.onsemi.com/pub/Collateral/1N4001-D.PDF
Standard disclaimers apply; I don't get money or other consideration
from any companies mentioned.
Matt Roberds
As I opined after your first ASCII ;-)
Right, is definitely the way to go, especially if there's substantial variation on the main supply rail.
This circuit looks hopeful, avoids the short circuit through the Adj, uses cheap readily available parts, and accuracy is power supply adequate. Adj currents cancel:
.. | | Metal Oxide
.. | [1.0K] 1%
.. | 317 | 1W
.. +--|I O|------------------------+---> Vmain-5 V
.. | | A | + | |
.. | | 1.25 | |
.. |0.1u | |0.1u
.. | 317 ----- |
.. | | I | |
.. | --|A | |
.. | | | O | |
.. | | [200] | 6.25mA |
.. | | | v |
The Hemulen
the two. ie if main rail is at 16V output at 11V, main rail drops to 15V
output at 10V etc. Need to pull up to 500mA from this tracking output.
between collector and base and resistor from here to ground but I'd also
like the tracked output to have some current protection in case the output
gets shorted.
short protection?
Many thanks for all the replies.. Tempting though the PIC/Motor based
solution is I think the LM1117 with 6.25V ref should do nicely.
John S
Don't forget that you will dissipate 2.5 watts at 500mA.
Jim Thompson said:
Looks like designing for production is not your forte ?:-}
Four units is a production quantity, right?
I don't do hardware design for a living; I do software for a living.
Recently it seems I have been doing various kinds of embedded software.
When I do anything with hardware it's usually for fun. Sometimes it's
for work, but then it often consists of providing goofy ideas to the
real official hardware guy. Mostly this provides comic relief to the
real official hardware guy. Once a year or so, it might help him get
unstuck - not by using one of my goofy ideas, but by helping him come
up with a goofy idea of his own that actually works. :)
This all furthers my goal of getting the board in my hands sooner, so
I can write the software, and then get on to the real fun of arguing
with the hardware guy about whether it's his crummy board or my crummy
code that is causing it to screw up. Sometimes we have a shootout in
the lab at noon with a compiler and an oscilloscope. If neither of us
turns out to be a good shot, the sheriff^Wboss comes by and talks to
both of us. Usually the boss decides that adding more crummy code is
cheaper than revising the crummy board. This gives me more code to
write, frees up the hardware guy to start working on the next board,
and frees up the boss to slide the bar ends to the left on the Gantt
charts, so everybody is happy? Right?
Matt Roberds
