Hi Guys,
Many thanks for the info. I am very new to electronics so what I may be stating above may seem like a load of gobbledeegook, apologies. What i am trying to build is a pressure display/switch circuit. I have a LDR switch circuit currently and somehow was trying to replace the ldr with the pressure transducer so that it would switch dependent upon pressure rather than light. I think the circuit is using a transistor to switch as opposed to a op-amp. I also have a panel meter, which has differential inputs, so I assume would connect without a problem. The confusion I am having is getting my head around differential signals as I have seen transducers that output via one wire as opposed to +/-.
Does this sound a feasable concept?
John
