transformer amperage
J.E
Apr 1, 2011
3
how do you calculate primary amps to secondary amps for a transformer? Is there a standard ratio for all transformers?:rolleyes:
duke37
Jan 9, 2011
5,364
No.
Transformers are designed for a particular purpose. If the voltage is transformed down by a factor of 2, then you would expect the permitted output current to be increased by a factor of about 2. With multiple secondaries, the permitted current in each secondary will depend on the wire diameter (resistance).
lexroxas
Apr 15, 2011
37
The primary and secondary currents depend on the turns ratio of the transformer. The turns ratio is N1/N2. N1 is the number of turns of the primary windings and N2 is the number of turns of the secondary windings. The current to turns ratio relationship is given by the formula: N1/N2 = I2/I1. I2 is the secondary current and I1 is the primary current. Also, the voltage to current relationship is given by the formula: V1/V2=I2/I1. V1 is the primary voltage and V2 is the secondary voltage.
