Transformer and LM317 Question
harrychoo
Sep 19, 2005
30
I want to ask a question about transformer as i very confuse about the multitap transformer.
In the circuit i put below, can i know what is the voltage for V1 and V2? Is it 16V or 32V? And is it V1 still an AC?
The diode is 1N5399.
Then below is the transformer that connected to LM317 to regulate the output voltage to charge my 12V 7Ah SLA battery.
D1,D2,D3,D5 = 1N5399
D4 = 1N4148
C1 = 0.1uF
R1 = 0.22R 5W
R2 = 240R
R3 = 2.54k
The charging voltage is to be set at around 14.4V from R2 and R3. So my question is how we set the charging current? Is it thru R1? If yes, then what is the formula to change R1 so that i can get different charging current? From the LM317 datasheet, i only can get the load impedance that related to R1 which is
Z1 = R1 x (1 + R3/R2)
Any realtion between this and the charging current?
audioguru2
Apr 6, 2004
12,026
Hi Harry,
Please convert schematics to a GIF or PNG file type on your hard drive the attach them directly to your post or reply. JPG file type is used for photos and appears fuzzy with schematics. Your file storage ImageShack server is usually to busy to work.
An LM317 can be a current regulator or a voltage regulator but not both at the same time.
I have made both for you. ;D
MP1
Dec 7, 2003
3,399
Harry,
It sounds like your question is mostly about how to calculate current and voltage ratings when using different rectification methods.
I have attached some diagrams with formulas. Hope it is helpful.
BTW- I also prefer to use jpg. Your picture looks fine when I click on it and it turns into a larger clearer image.
MP
harrychoo
Sep 19, 2005
30
Thanks audioguru and MP for the reply.
@audioguru
Is it possible to make it using only 1 LM317? This is because almost all the battery charger circuit in the end market UPS system that I traced, they only using single LM317. And also I want to reduce cost if possible. If based on my earlier circuit, can I know what is the output current? How much power that the LM317 need to dissipate in my circuit and your circuit? Thanks a lot.
@MP
Then from my circuit, is it consider as Full Wave Resistive Load? If yes, then it should contradict with audioguru circuit where the input voltage to his first LM317 is 21.8V. What is the input voltage to my LM317 then? If it is a Full Bridge Resistive Load, then the input voltage to LM317 should be around 14.4V (0.45 x 32V) but ain't it too low since the output voltage i also want 14.4V?
MP1
Dec 7, 2003
3,399
I recommend that you add the capacitor. You do not want the resistive load example in this application.
MP
harrychoo
Sep 19, 2005
30
MP
If use the Full Wave Capacitor Load, from my circuit, the calculation is 0.71 x 16V or 0.71 x 32V?
audioguru2
Apr 6, 2004
12,026
In your original circuit, the 0.22 ohm resistor ruins the LM317's voltage regulation since the resistor causes the output voltage of the circuit to drop with increasing output current. You would set the voltage-adjusting pot for the amount of trickle-charge current you want. I have re-sketched it for low cost.
The output voltage depends on the output current. If its voltage is set to 14.4V across the battery at a low current for trickle-charging, then its charging voltage is limited to about 10.4V at 1.5A.
About 15.1W at 1.5A for your circuit or for my 2nd circuit. It would be much less if the transformer is the odd voltage of 13V + 13V. In my 1st circuit, the two LM317's would share the dissipation but not equally.
MP's drawing shows that the entire transformer's secondary AC voltage of 32VAC times 0.71 results in a peak voltage of 22.7VDC. My circuit shows it drop about 0.9V after the rectifiers.View attachment 38309
harrychoo
Sep 19, 2005
30
Can i know what is the main difference between your "Battery charger 2" with my circuit earlier other than those protection diode?
The pot in your battery charger 2 is used to set current but not voltage? Can u explain why this can happen?
Let say, i confirm that i want 14.4V at the battery there, then can I just replace the 500R pot and 1k res with a single res? If that so, what is my current?
Last question is what is the purpose of the 0.22R?
Thanks again
audioguru2
Apr 6, 2004
12,026
D3, D4 and C1 aren't necessary.
The circuit regulates the voltage poorly with the 0.22 ohm resistor, and doesn't regulate the current.
The circuit is just an amplified power resistor and changing the pot's setting changes the resistance.
The pot setting also limits the max voltage when there is low current.
Make it, set it and measure the pot and resistor's total resistance. Replace them with a resistor of the same value. Then the current depends on the battery's voltage. High current when the battery's voltage is low and low current when the battery's voltage is high. Just like a power resistor fed from 14.4V.
It senses the current then the LM317 effectively duplicates and multiplies its value.
harrychoo
Sep 19, 2005
30
Is that ok and what happens if i omit the 0.22R?
Can u help me in this too?
http://www.electronics-lab.com/forum/index.php?topic=5518.0
Actually, i plan to make a similar charger with monitoring either by using comparator or microcontroller ADC and will cut off off the charging process once the battery is fully charged.
Any idea on this?
Thanks  ;D
indulis
Nov 21, 2005
488
The .22 ohm resistor does not ruin the LM317's voltage regulation. D5 is another story as far as regulation... it's forward voltage will change with current and temperature. The point that is regulated is the "node" from which the feedback is taken. In this case the "output" side of the .22 ohm. The .22 ohm also helps a little with power dissipation. As the current increases, some of the power that would have been dissipated in the regulator, is now dissipated in the resistor. Also, don't be to fast to get rid of the capacitor C1 on the "adj pin". These regulators can and will oscillate sometimes without it!!! If you leave it, the worst that can happen is the transient response will be a little slower.
audioguru2
Apr 6, 2004
12,026
Hi Harry,
Where's Sasi?
His old LM301 doesn't work with its input voltages anywhere near its positive supply.
The circuit was probably designed for an old LM307 which is no longer made it and a TL082 work fine with their inputs at the positive supply.
Hi Indulis,
The datasheet for the LM317 describes how it amplifies the value of a resistor of only 0.05 ohms to ruin its excellent voltage regulation. The 0.22 ohm rersistor in this circuit is 4.4 times worse.
The LM317's I have used without a capacitor at the adj. pin work fine without any oscillation when their circuit has the recommended input and output capacitors.
harrychoo
Sep 19, 2005
30
@audioguru
I not sure where is Sasi  ???
Is it mean that his circuit no longer work? Do you have any idea on how to monitor the charging process? Do we need to monitor the battery voltage OR charging current during the charging process? I might want to do this with microcontroller's ADC.
Off-topic : Can I know how is the voltage waveform for our main AC? We have Neutral and Live line respectively but how the waveform gonna looks like in each of these lines with respect to time? Is it possible to view the 240VAC waveform by using digital or analog oscilloscope? Or do we need certain special equipments? What is the procedure?
Can I know by using op-amp, can we built some circuit to determine the input AC and its' frequency with the usage of microcontroller?
Thanks ya
indulis
Nov 21, 2005
488
Ahhhhh yes....... I should have checked the data sheet first. Yup, since the reference voltage is between the output pin and adjust pin (not adj pin to common... I guess I've been around TL431's too long), any resistance in series will screw up the load regulation (not line regulation). As for the capacitor C1..... I have had circuits with a LM338 oscillate under certain line/load conditions without out it ("conditionally stable").
harrychoo
Sep 19, 2005
30
audioguru said:
I explained why his circuit won't work with an old LM301. I also explained why a TL081 will work fine instead.
Just change the LM301 with TL081 without any modification?
Monitoring the voltage or current of a lead-acid battery charger is useless like watching grass grow. It gives little indication of how much the battery is charged. It would only show if the battery is shorted, but the smoke would also give good indication. It might show if the battery was disconnected.
The reason i want to monitor is not want to know how far it is being charged but i want to terminate the charging once it full. Any idea?
The mains is supposed to be a sine-wave. It will show short notches when high-current appliances turn on, and spikes when inductive loads turn off. Lamp dimmers cause interesting-looking small changes to the sine waveform.
There isn't any reason to view the mains because there isn't much that you can do about it.
Actually i need to view the main because i will implement inverter later part and i want to check its waveform. And the question i mean previously is, the neutral and live line both also output sine wave simultaneously? Or 180 degree out of phase or others?
If the voltage and frequency of your mains changes enough to worry you, then it is broken and needs replacement.
Same here too, i need to built an universal UPS system with AVR and different input AC voltage and 50Hz/60Hz. So i need to detect the input AC voltage in order to do the AVR and i need to detect whether it is 50Hz or 60Hz so i will output the same frequency on the inverter side.
harrychoo
Sep 19, 2005
30
thanks for the reply.
Actually, i still not fully understand the statement "any series resistance will screw up the load regulation"
Can explain further?
audioguru2
Apr 6, 2004
12,026
If you compare the old LM301 with the newer TL081 you will see that the LM301 needs the 100pF capacitor but the TL081 won't work properly with it. Remove it.
You have selected a circuit that reduces the charging current when the battery's voltage and current reaches amounts set with pots. You don't trust the circuit? You don't trust your settings?
Neutral is nearly the same as ground. For safety, you will use optical or a transformer for isolated coupling.
Pretty complicated, good luck.
