Transformer and LM317 Question
indulis
Nov 21, 2005
488
Like many 3 terminal regulators, there is a reference voltage between the output pin and the adjust pin. In the case of the LM317, it's 1.25V
audioguru2
Apr 6, 2004
12,022
Hi Indulis,
The heatsink tab is connected to the output terminal of an LM317. To avoid having output current in the wire connected to the voltage-setting resistor, my LM317 project uses the tab as the output terminal and the output pin for the voltage-setting resistor. Then the voltage regulation with changing load current is so good that I measure hardly any change in voltage at the output. ;D
