Transformer for voltage booster?
HarryA1
Mar 4, 2009
481
Hello from cold and snowy NE PA,
In my quest to convert 9 - 12 volts dc into 140 volts dc I purchased a "40W DC-AC 12V To 220V Step-up Transformer Boost Module Inverter" via Ebay. I also purchased a 220 volt to 120 volt 50-60 hertz step down transformer; the type travelers use.
But the inverter's output is 38.4k hertz!  So my transformer is useless here. I am wondering if one can find a transformer that will handle that frequency and is two to one?
I am driving a class D pulse amplifier that outputs 100 Volts peak at a current of 0.10 amperes max. The pulse is 0.4 ms duration at and interval  of 2 ms. So I am thinking that I need: 100v * 0.10 * 0.4/2 = 2.0 watts for the amplifier output so I am thinking about 10 watts for the amplifier and the conversion from 120 ac to 140 dc.
audioguru2
Apr 6, 2004
12,022
It is inefficient to boost the voltage too high then drop it down.
Why does the amplifier need a supply of 140V to produce only 100V? Won't the extra 40V cause lots of power waste as heat?
HarryA1
Mar 4, 2009
481
You points are well made; thanks.
On day one I found two voltage boosters on Ebay that gave more than 100 volts so I ordered both of them from China. The first  one I received was a 12v dc to 200 v dc. After connecting it up and adjusting it for 200 v I put a 100k resistor across the output  and got 2 volts output! It took a one mega-ohm load to keep 200 v.
The   second one (12v dc to 220 v ac) works well. I connected it to the 220v to 120v step down transformer and into a full wave bridge rectifier with a 100mfd capacitor and got 140 v dc; 9.6 volts input. With a 8.4 v NiMH rechargeable battery I get 128 v dc.
So I am happy with that  and  very surprised that the 50/60 hertz transformer works at all!
